premature fuel-cut at 8650rpm!!! heeeelllpp!!!
Old Oct 31, 2001 | 04:12 PM
dragster's Avatar
New User
Default premature fuel-cut at 8650rpm!!! heeeelllpp!!!
Can anyone tell me why my car fuel-cuts at 8650rpm now. I just couldn't get it past 8650rpm. It used to be easy to get it up to 9000rpm. Please analyse my car set-up below and tell me what's happened???
I'm very sad now.
Old Oct 31, 2001 | 04:25 PM
MrBite's Avatar
Default Re: premature fuel-cut at 8650rpm!!! heeeelllpp!!! (dragster)
Is it the stock tach? Those can be off by up to a few hundred.
Old Oct 31, 2001 | 04:30 PM
PrjctDC2-R's Avatar
New User
Default Re: premature fuel-cut at 8650rpm!!! heeeelllpp!!! (MrBite)
check oil
Old Oct 31, 2001 | 04:35 PM
dragster's Avatar
New User
Default Re: premature fuel-cut at 8650rpm!!! heeeelllpp!!! (PrjctDC2-R)
The rpm was displayed by my VAFC readings when I hold the highest point. So it isn't the tacho reading, its the actual ecu reading.
What oil? Engine oil? Why? I've just changed to Honda Vtec oil about 2500km ago.
Please help!!!
Old Oct 31, 2001 | 04:37 PM
PrjctDC2-R's Avatar
New User
you hit hit a reading of 9000rpm on your V-AFC before?!?.. stock ecu?
Old Oct 31, 2001 | 04:43 PM
dragster's Avatar
New User
pretty close to 9000rpm, think should be arould 8800rpm when i shifted. but couldn't do so now. why
Old Oct 31, 2001 | 04:55 PM
PiYoImuT's Avatar
What is Honda VTEC OIL? fill me on this one please..
Old Oct 31, 2001 | 04:59 PM
CPR's Avatar
CPR
So you're registering 8650rpm on the V-AFC. What's it registering on the stock tach? Maybe for some odd reason, it is your VAFC that's off.
Old Oct 31, 2001 | 08:34 PM
dragster's Avatar
New User
Default Re: premature fuel-cut at 8650rpm!!! heeeelllpp!!! (CPR)
My tacho & vafc both reads the same readings. I don't think it is a display inaccuracy. BTW, Honda Vtec oil is the oil recommended by Honda. Supposedly lighter to rev.
Any body can help me please do.
Old Oct 31, 2001 | 08:42 PM
killingtime's Avatar
What kind of ECU are you running?
Demian
Old Oct 31, 2001 | 10:07 PM
dragster's Avatar
New User
Default Re: premature fuel-cut at 8650rpm!!! heeeelllpp!!! (killingtime)
Spoon street ecu. Fuel cut at 9000rpm.
Old Oct 31, 2001 | 11:30 PM
Racer-X's Avatar
Have you tried reset your ECU? I would try that and see if that helps any could some crazy glitch in the ECU or something I had reprogrammed CRX ECU recently do something similar until I reset it. I'm not sure what else it could be if your using the proper fuilds in the engine and allowing it to warm up before engaging vtec unless it's something electronic or maybe in the engine it self.. But I'd try resetting the ECU first.
Old Nov 1, 2001 | 04:47 AM
Stock-DC2's Avatar
New User
Is it the real Spoon ECU or just some copy chip of it? If it is the real one, I would call up whoever you brought the ECU from and ask for some technical help. I am sure those Spoon dealer out there would love to help you out.
UPYOURZ
Dec 23, 2005 06:33 AM
1999CivicSi
Sep 24, 2005 12:00 PM
tianporn
18
Sep 18, 2004 07:54 AM
92b16vx
Oct 25, 2003 02:07 AM
pushin redline 6
Mar 5, 2002 07:20 PM
