Problem /w MOtor SWap....
Old Apr 25, 2004 | 12:48 PM
fwdftw's Avatar
Default Problem /w MOtor SWap....
k We have the motor droped EVERYThing is hooked up.. crank it It turns.. just no start.. the plugs are getting NO Spark at all.. we replaced the coil inside the alternator.. Still no spark.. any sugestions?
Old Apr 25, 2004 | 02:09 PM
SiR831's Avatar
Default Re: Problem /w MOtor SWap.... (Milano92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">k We have the motor droped EVERYThing is hooked up.. crank it It turns.. just no start.. the plugs are getting NO Spark at all.. we replaced the coil inside the alternator.. Still no spark.. any sugestions? </TD></TR></TABLE>
what kind of motor and car?
Old Apr 25, 2004 | 02:11 PM
toolowsol's Avatar
Default Re: Problem /w MOtor SWap.... (SiR831)
replace the coil in the distributer, not the altenator
Old Apr 25, 2004 | 02:12 PM
deSigi's Avatar
Is everything wired up correctly for the distributor in the wiring harness?
Old Apr 25, 2004 | 02:13 PM
2lua's Avatar
check your grounds.
Old Apr 25, 2004 | 02:18 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (2lua)
double check your grounds. if you think it might be your dizzy just swap it out with another dizzy to see if that solves your problem.
Old Apr 25, 2004 | 02:39 PM
ABK's Avatar
ABK
Default Re: (AzntaggeR)
Yeah what motor and what ECU. And did you mean dizzy instead of alternator because the coil is in the dizzy. Check conections. Do you get fuel?
Old Apr 25, 2004 | 03:32 PM
DRKSol's Avatar
check grounds
Old Apr 25, 2004 | 07:38 PM
fwdftw's Avatar
checked grounds.. if the grounds werent on it wouldnt turn.... i smell fuel on the plusgs.. its gettin fuel... we changed the coil on the dizzy.. i duno whats wrong ..
Old Apr 25, 2004 | 07:39 PM
fwdftw's Avatar
its a d15z1 SOHC vtec
Old Apr 25, 2004 | 07:43 PM
ABK's Avatar
ABK
Default Re: (Milano92Hatch)
it has to do something with connections to the Dizzy then.
NeKe1point0
Jan 21, 2008 06:07 PM
NeKe1point0
Dec 16, 2007 02:10 PM
skipunk
10
Jul 2, 2007 12:33 PM
SOUTHCREX
Jun 18, 2002 08:16 PM
