Broken wheel studs HELP ASAP!
I broke 3 wheel studs on the drivers side and 1's still on. I want to replace them all. I'm having problems.
I've manage to remove the cailper and disk brake rotor, but how do I remove the hub that has the wheel studs on them? Do I need an axle nut to undo the axle from the hub? or do I just pull the hub outwards toward me as hard as I can?
I need my car for work tomorrow.
Any other tips or advice would be helpful!
Some people here disagree on my tactics on this but I did it to my car and it works fine...
http://www.fourthgenhatch.com/wheelstud.html
You can have them replaced in a couple minutes.
use a dremel tool to saw off the studs as much as u can like up to were they go into the hub...
u can then use a screw driver and hammer to drive out the studs, i hammered new 1s in from behind, worked fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ u »</TD></TR><TR><TD CLASS="quote">yeah I already saw your link and everything all I want to know is how to remove the wheel hub using the axle nut?
If someone can tell me that I'm good to go.</TD></TR></TABLE>
Read what I put, you remove the axle nut with a socket then you need a slide hammer or press to get the assemble out.
cheifncomer
Nov 21, 2008 04:15 PM
wraetthu
Nov 17, 2006 03:56 PM
