put LSD in today, now NO reverse
Old Apr 24, 2004 | 10:48 PM
JonGP4's Avatar
Default put LSD in today, now NO reverse
ok well i finially got around to putting a LSD in my CRX, and everything went pretty smooth, followed the helms by the nose.. and no problems till i get it all back together and the ****** won't go in reverse, and it grinds into 5th.. i take it all back apart, and everything looks right.. i didn't touch the mainshaft or countershaft, simply removed them together, and took out the differencial??.. so i dun no,.. any tranny guys here?.. i'm fixing to head out and pay someone to fix it.. if worse comes to worse, my local pick and pull has them for 75 bucks, and i'll just pay another 100 to have a professional install it.. but i dun no, my best friend who had done this before was helpping me, and he didn't get it?.. any advise?
sorry for the spelling its late, i'm pissed, and buzzing
Old Apr 24, 2004 | 11:11 PM
Louie B.'s Avatar
Default Re: put LSD in today, now NO reverse (JonGP4)
Double check that you didn't put the reverse gear in upside-down. Common mistake.
Old Apr 25, 2004 | 12:10 AM
D16A6Turbo's Avatar
Default Re: put LSD in today, now NO reverse (thumpu77)
Sorry I don't have an answer for you, but I'd try this same question in Tech, Forced Induction and All motor...there's some good knowledge in those forums...
Old Apr 25, 2004 | 12:27 PM
EFSiR's Avatar
take lots of close up pictures and we'll take it from there. Is this B or D tranny?
Old Apr 25, 2004 | 12:29 PM
b16_madman's Avatar
Default Re: put LSD in today, now NO reverse (EFSiR)
i'll try to help, make sure to double check stuff that it all shifts etc...before you put it back together, row the gear selector thru all of them etc.
Old Apr 25, 2004 | 03:18 PM
JonGP4's Avatar
Default Re: put LSD in today, now NO reverse (B16_madman)
ok, it'll go in reverse when its all apart.. soon as i put the case on.. its very hard to go in reverse, it'll go, but i have to hammer it in.. i'll see what i can do about pics
Old Apr 25, 2004 | 05:01 PM
1's Avatar
Might you have bent the shift fork?
Old Apr 25, 2004 | 08:51 PM
JonGP4's Avatar
Default Re: put LSD in today, now NO reverse (1)
how?.. all i did was remove it, no force was used in anything?
Old Apr 25, 2004 | 08:54 PM
ijjz's Avatar
Try putting it in first then reverse?
Old Apr 26, 2004 | 08:55 AM
JonGP4's Avatar
Default Re: put LSD in today, now NO reverse (ijjz)
ok it'll go into all other gears, but reverse i have to hammer it in.. when its in, its hard as hell to turn.. i'm ready to buy another trany
Old Apr 26, 2004 | 10:14 PM
Louie B.'s Avatar
Just do this to it:
Old Apr 26, 2004 | 10:20 PM
JonGP4's Avatar
oh good god.. i don't even want to imagine putting that back together.. lol
i'm taking in to a trany shop in the morning, if they charge me more then 100 bucks, i'm pulling the LSD out, and getting another trany, then paying for them to install it
Old Apr 26, 2004 | 11:02 PM
ijjz's Avatar
Default Re: put LSD in today, now NO reverse (D16A6Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I don't have an answer for you, but I'd try this same question in Tech, Forced Induction and All motor...there's some good knowledge in those forums...</TD></TR></TABLE>
Did you try this yet? Those guys know a lot.
Old Apr 27, 2004 | 12:07 AM
JonGP4's Avatar
ive got more replies here, then there.. however most of the replies here aren't as helpful..
Old Apr 27, 2004 | 03:29 AM
EFSiR's Avatar
hey, put the trany together and just before the step you put hte casing on, take snap shots, that's what I ment...
Old Apr 27, 2004 | 09:42 AM
johnjw's Avatar
sometimes when the shift forks are not all lined up and you try moving the shifter....or it sounds as though you hamered the shift rod to try and get it to move....you can bend that "u" shaped peice that slides through all the bottom of the shift forks....that "u" shaped peice bends really easy so be careful.'
yea and you might also want to make sure the reverse gear is in the right way, I think the big cone goes down.
good luck
Old Apr 27, 2004 | 10:53 AM
USDM 4G VTEC's Avatar
check the fifth gear select ring
the select rings have 2 longer teeth than the other and these 2 teeth are 120 deg apart
make sure u got them lined up right
that caused me once not to align my gears
also make sure u have not bent and or moved out of place the synchro lil ring spring tingy
kixcrx
13
Dec 13, 2006 11:28 PM
speedKILLS
Jul 24, 2006 05:52 PM
JonGP4
May 2, 2004 12:20 AM
Nameless RB26
Dec 9, 2002 08:53 AM
