Valve clearance with A6/Z6 mini-me, 2 layer HG and milled head
Old Apr 24, 2004 | 10:47 PM
jetpilot's Avatar
Default Valve clearance with A6/Z6 mini-me, 2 layer HG and milled head
Has anyone tried this??? I want to do it but Im afraid the valves will hit the pistons, im milling 20 thou of the head (.5mm) and using a Y8 HG with the middle layer pulled out. Hoping for mid 10 cr.
any input is apreciated, thanks
Old Apr 25, 2004 | 12:44 AM
1point5CRX's Avatar
Default Re: Valve clearance with A6/Z6 mini-me, 2 layer HG and milled head (jetpilot)
youll be very close to 10:7.1 - 10:9.1
93 oct.
Old Apr 25, 2004 | 06:02 AM
jetpilot's Avatar
im going to use 95 octane
I want to know if the valve clearance will be good enough for a 59300 and a cam gear (+-3degrees)
Old Apr 25, 2004 | 06:56 AM
91' Z-6 Canadian hatch's Avatar
Default Re: (jetpilot)
as far as your clearence issue with the 59300 cam it has .468" valve lift. oh what pistons are you going to use if stock you'll be fine and since there is no specs on this cam yet as far as degreing that i've seen set up your cam gear at 2dgrs r. just to start out .
Old Apr 25, 2004 | 10:05 AM
jetpilot's Avatar
are your calculations with a 020 milled head and 2 layer HG??
9hatchturbo5
Feb 1, 2013 03:20 PM
SCR ZC-T
Apr 21, 2007 02:50 PM
digitalcongo
Apr 21, 2006 12:08 AM
DanM
Apr 27, 2003 01:09 PM
Mike D
Apr 3, 2003 04:53 PM
