can a vacuum leak cause decreased performance?
Old Apr 24, 2004 | 09:08 PM
aut0tek's Avatar
Default can a vacuum leak cause decreased performance?
Just curious... and if so, how significant of a decrease would you see with let just say... one of the smaller diameter vacuum lines open on the end? lol.
Ratliff
Old Apr 25, 2004 | 01:04 PM
aut0tek's Avatar
Default Re: can a vacuum leak cause decreased performance? (aut0tek)
anyone?
Old Apr 25, 2004 | 01:09 PM
fourthgenhatchB17's Avatar
Performance is decreased with vacuum leak(s).
Old Apr 25, 2004 | 03:32 PM
jazz215's Avatar
Default Re: can a vacuum leak cause decreased performance? (fourthgenhatchB17)
i recently found a vaccum leak.. and when i plugged it up.. my idle problem went away.
Old Apr 25, 2004 | 06:33 PM
will3ishere's Avatar
a vacuum leak causes the car to run richer because it is unmetered air entering the engine
Old Apr 25, 2004 | 07:04 PM
91DA9's Avatar
Default Re: can a vacuum leak cause decreased performance? (will3ishere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by will3ishere &raquo;</TD></TR><TR><TD CLASS="quote">a vacuum leak causes the car to run richer because it is unmetered air entering the engine</TD></TR></TABLE>
Wouldn't the MAP sensor catch that? I know my car doesn't even have an airflow meter, just a MAP.
Old Apr 25, 2004 | 09:12 PM
aut0tek's Avatar
Default Re: can a vacuum leak cause decreased performance? (91DA9)
cool... Well now I have bigger issues anyways... thanks guys.
Darn thing is smoking pretty bad but compression checks like it always has... 210-240-240-240.
Ratliff
Old Apr 25, 2004 | 09:27 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aut0tek &raquo;</TD></TR><TR><TD CLASS="quote">cool... Well now I have bigger issues anyways... thanks guys.
Ratliff</TD></TR></TABLE>
Oil rings can be going out while the comp rings are still good. What color smoke?
Old Apr 25, 2004 | 09:39 PM
aut0tek's Avatar
Default Re: can a vacuum leak cause decreased performance? (blah13)
blueish... oil smoke I'm pretty darn sure. :-/
Oil rings gone but comp rings good wouldn't give me a MASSIVE performance decrease though would it?
We're talking 10 flat in the 1/8 on 11.1:1 comp forged bottom end LS/VTEC in a DA integra that weighs 2180 with a full tank of gas. :-(
Ratliff
Modified by aut0tek at 6:08 PM 4/26/2004
Old Jan 4, 2005 | 02:08 PM
ar0nic's Avatar
whats up dude im in chas and having a vac leak too just put my swap into my EG and having idling/surging problems. ive checked iavc and fitv i think its a vac leak in the intake manifold
good luck with your vac leak wish i could help more.
Old Jan 4, 2005 | 10:28 PM
PrettyLude's Avatar
start checking it was carb cleaner
MenaceL.A.671
Aug 29, 2009 11:24 AM
EG9_808
Mar 2, 2007 11:23 AM
ic89
Oct 18, 2006 08:24 AM
efyou
Dec 22, 2005 03:21 PM
bOOsTiNSoHcVtEc
May 12, 2004 02:50 PM
