OBD0-OBD1 VTEC Wiring
Old Apr 24, 2004 | 08:36 PM
RobbieG35's Avatar
12 Years Strong
Default OBD0-OBD1 VTEC Wiring
I am running a chipped P28 and am wondering do I need to wire up VTEC like an OBD1 car and if so where do I find ECU pins for VTEC?
Old Apr 26, 2004 | 10:12 AM
tgreaves's Avatar
Default Re: OBD0-OBD1 VTEC Wiring (HybridHatch88)
Im guessing you have a obd0-obd1 converter there.. One of the pins should say its a vtec wire..
You just run that wire into the engine compartment and hook it to the vtec noid.. I think you also have to run a wire to the vtec pressure switch or something, I use a AEM EMS so I didnt have to worry about that one..
Old Apr 26, 2004 | 01:25 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
up for some info (i have the same wiring ahead on my 91 teg)
you'll need an obd0-obd1 jumper thats for sure
Old Apr 26, 2004 | 02:39 PM
RABHonda's Avatar
you dont need to use the p28 ecu. you can use an obo-0 ecu and redo the board. i have a friend who just did that with his 88 crx he dropped a fully built d16z6 into.
Old Apr 26, 2004 | 09:54 PM
tgreaves's Avatar
Default Re: OBD0-OBD1 VTEC Wiring (RABHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RABHonda &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to use the p28 ecu. you can use an obo-0 ecu and redo the board. i have a friend who just did that with his 88 crx he dropped a fully built d16z6 into. </TD></TR></TABLE>
I know that.. I was running a chipped obd0 pm6 for a while.. He said that he had a chipped p28 and was wondering about vtec.. If he wanted to use the vtec for an obd0 the best way would be to use a pr3 or pw0 obd0 one..
xxghettothixxx
Jun 29, 2007 09:42 PM
Bulli Kid
Jun 11, 2007 03:17 PM
92accordh22a
Dec 16, 2006 07:21 AM
DiSbaDbOi
Oct 31, 2004 04:28 PM
