Drag turbo t3/t4 max hp?
Old Apr 24, 2004 | 07:01 PM
Turbo-Honda's Avatar
Default Drag turbo t3/t4 max hp?
Drag t3/t4 E 50 .63 exhast ..
Could this turbo reach into 400hp range??? Or I need to upgrade bigger turbo???
Motor is completely rebuild 2.0L, 9:1cc,. 3''exhaust, hondata, 650cc, 255lph, precision IC 2.25 - 2.5 piping..etc...
Thanks guys...
Old Apr 24, 2004 | 07:18 PM
98gsrTEG's Avatar
Default Re: Drag turbo t3/t4 max hp? (Turbo-Honda)
you can't base a trubo on how mauch hp it can produce, rather how much boost it can safely run without surging.
and on that turbo it looks like it would be around 18psi. in my opinion with higher compression and good tuning you could get 400whp out of that
Old Apr 24, 2004 | 08:39 PM
11psiTurboSI's Avatar
Default Re: Drag turbo t3/t4 max hp? (98gsrTEG)
Ive seen 400hp off 28psi with the stock drag turbo in a ls motor
Old Apr 24, 2004 | 08:44 PM
rocket256's Avatar
Default Re: Drag turbo t3/t4 max hp? (9psiTurboSI)
the turbo is rated at 450hp
Old Apr 24, 2004 | 08:47 PM
98gsrTEG's Avatar
Default Re: Drag turbo t3/t4 max hp? (rocket256)
the 400 hp on the drag kit was not on the drag turbo, it was on a .78 gerrett turbo. the rest was a drag kit
and again you can not rate a turbo by how much hp it can produce!!!!
Old Apr 24, 2004 | 09:31 PM
PureTeg420's Avatar
I've seen 430whp @ 23psi using the drag .54 trim t3/t04e. ls/vtec built...
Old Apr 24, 2004 | 10:36 PM
AspectIndustries's Avatar
Default Re: Drag turbo t3/t4 max hp? (PureTeg420)
Doesnt DRAG kits come with Turbonetic Turbos? Correct me if im Wrong.
Old Apr 25, 2004 | 03:51 AM
I plan on going 400hp max. Could anyone can tell me what psi I run in a drage stage II E 50trim .63 ... I heard it somewhere in the 20psi range.. Was that correct???
Thanks for replies...
Got traction
Jul 8, 2008 07:22 PM
B17aTrbo
Dec 2, 2003 11:49 AM
Double 06
Jul 10, 2002 01:35 PM
