Nitrous System (WHICH ONE)
I'm interested in putting a nitrous kit on my built B16A. I was curious what you guys think is the best nitrous kit out there. The ones I have been looking at are; N.O.S., NX, Venom and Zex.
Let me know your opinions, thanks in advance.
Nitrous Express Sport Compact All EFI "Stage One" Single Nozzle Nitrous System
Utilizing the patented "Shark" nozzle, these systems are fully adjustable, 35,50,75 horsepower for 4 cylinder and V-6 applications, and up to 150h.p. for V-8 and V-12 cars. These systems require no engine modifications, operate on stock fuel pumps, and require no timing retards. The ultimate solution to make your import a "Rocket". Any horsepower settings above the recommended levels require "NX Power Booster" fuel additive to prevent detonation
Universal Nitrous Oxide System Nitrous Kits
Through years of involvement with all forms of high performance racing, NOS has evolved into the world's largest manufacturer of performance nitrous systems. NOS designs and engineers nitrous systems for virtually anything with an internal combustion engine from stock to highly modified cars. Research and development, engineering and technical support assures you of great results from NOS. Nitrous Oxide Systems carries a complete line of easy to install, state-of-the-art nitrous systems for cars; and many of them are 50 state emission legal.
Venom VCN-1000 Nitrous System
The VCN-1000 is Venom's new entry level nitrous oxide system. This nitrous oxide system is built using Venom's proprietary closed loop control system which ensures the proper fuel ratio under all operating conditions. This nitrous oxide system features an advanced microprocessor based control module that will automatically terminate the flow of nitrous oxide if the air/fuel mixture becomes too lean. You control the flow of nitrous oxide to your engine using various sized nozzles (each kit contains 4 nozzles), the module will automatically control the fuel flow to your engine using your existing fuel injectors. No modifications to fuel pressure or fuel system plumbing is required and best of all it works on new fuel systems that do not include a fuel return line.
This nitrous oxide system inludes a driver information display that indicates the air/fuel mixture (rich/lean) and system status.
ZEX Nitrous Kits
With ZEX™, you keep you hands on the wheel and your eyes on the finish line. When armed, your ZEX™ nitrous kit kicks in at full throttle automatically thanks to the ZEX™ Nitrous Management Unit. So while your competition is trying to find the nitrous switch, you've already won. Kits come complete with all mounting hardware, hoses, tap, brackets, etc...
ZEX Nitrous Kits
I think you should talk to Raver motorsports, their nitrous daughterboard for OBD1 ECUs is absolutely the best way to go. You get perfect ignition and fuel control, but it requires some tuning to make it work, it is not an out of the box solution that you can bolt on and run safe rich (meaning AFR wanders all over the place, but is mostly rich to too rich).
its aight dude I sell nitrous at my work so I can get all my kits and stuff I was just wondering what you guys thought of the different kinds of kits do you have any info on the different ones?
I have the zex wet kit and its pretty nice i gain 42 hp of of it and a **** load of tq of of a 55 i went from 154 to 212 not bad for 300 bucks. their are many nice kits out there i just got the zex kit cause my buddy was selling it for cheap
ImportCarPartsPlus
Dec 25, 2008 01:02 PM
amy
Oct 5, 2007 11:10 AM
