LS/VTEC or GSR, Built, Turbo = 400+ whp... how?
Old Apr 24, 2004 | 04:33 PM
Sivik's Avatar
Default LS/VTEC or GSR, Built, Turbo = 400+ whp... how?
Hey,
I'm looking to do a swap this summer, and I know I want 400+ whp (like everyone else). I did a search and read some old post. Basically I'm undecided on the block I want. Either B16, LS/VTEC, GSR, or B20B/VTEC. Of course I'm gonna build internals. Turbo I'm looking at the SC61. Any advice?
Old Apr 24, 2004 | 05:03 PM
5STAR3's Avatar
Default Re: LS/VTEC or GSR, Built, Turbo = 400+ whp... how? (Sivik)
what is your question?
in the title you asked how you can make 400whp from a vtec motor -easy
then in the post you just rambled about your crazy ideas?
you need to do a little more searching
Old Apr 24, 2004 | 05:50 PM
Sivik's Avatar
what im asking is which block would be the best one to go with? ive heard stories of probs with the LS/Vtec combo. so that is what im asking. which engine?
Old Apr 24, 2004 | 05:56 PM
Kelly.'s Avatar
I've quit using this account
gsr block with ls crank and rods/gsr pistons...
Old Apr 24, 2004 | 05:58 PM
quikB18B's Avatar
Default Re: (Sivik)
If you have the $$$ go Fully built Turbo Gsr
Old Apr 24, 2004 | 09:31 PM
rocket256's Avatar
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">If you have the $$$ go Fully built Turbo Gsr </TD></TR></TABLE>
That would be nice.
Old Apr 25, 2004 | 01:42 AM
Sivik's Avatar
money not a problem... but want to stay within a limit, ie don't want to basically "buy" a new car.
Old Apr 25, 2004 | 07:40 AM
numba1's Avatar
Default Re: (Sivik)
just go gsr with upgraded rods and pistons, hondata or comparable ecu(aem, etc.)and sc61. 400whp no problem. Might need some sleeves for added insurance,and a good tuner. but very possible.
Old Apr 25, 2004 | 08:27 AM
thermal's Avatar
Default Re: (numba1)
I;m doing the same starting this winter. I think I'm going for building an LS/VTEC set-up. Build the bottom end...... sleeved, LC pistons, rods........ still on research phase tho. I might change my mind again......
Old Apr 25, 2004 | 09:44 AM
Sivik's Avatar
im tempted to do GSR since the VTEC head is matched and already there, don't want to bother with the Frankenstein motor, but who knows? i can't decide...
sc61 or sc34?
Old Apr 25, 2004 | 09:56 AM
EVIL_AWD's Avatar
Default Re: (Sivik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sivik &raquo;</TD></TR><TR><TD CLASS="quote">im tempted to do GSR since the VTEC head is matched and already there, don't want to bother with the Frankenstein motor, but who knows? i can't decide...
sc61 or sc34?</TD></TR></TABLE>
I'd go with the GsR block and SC61 turbo.
Old Apr 25, 2004 | 10:01 AM
97lstegra's Avatar
Default Re: (ITR420)
I'll be doing one myself soon. Goin with an LS/VTEC though. IF I were you i'd do the GSR block with LS crank and built internals. I'd do that myself but I already have a built LS block and a stock one so there's no point in getting a thrid
Old Apr 26, 2004 | 12:59 PM
Sivik's Avatar
ok, now if i get a motor with everything including ecu and main harness, do i have to do any additional wiring or shouldn't it all be plug and play?
Old Apr 26, 2004 | 03:56 PM
B18c1turboedEK's Avatar
Default Re: (Sivik)
WHy does it help too run a LS Crank???
Old Apr 26, 2004 | 04:01 PM
MaxSterling's Avatar
Default Re: (Koticcivic4u)
ls crack has long stroke, therefore faster pistion speeds per given rpm compared to gsr crank, therefore more torque but dangerous/sacrifice higher rpms b/c of piston speed.
Old Apr 26, 2004 | 04:44 PM
Sivik's Avatar
if i did use the LS crank, what would need to be done to it to prevent the upper end dangers?
Projectjdm4
14
Jul 20, 2007 01:15 PM
k20o2o4civic
Jul 27, 2006 11:01 PM
limpy
Jul 14, 2005 01:40 PM
LSEGHATCH
Dec 29, 2004 02:41 PM
EFin' Kyle
Oct 11, 2004 04:01 PM
