I need help with my crx w/b16
Old Apr 24, 2004 | 01:31 AM
91b16acrx's Avatar
Default I need help with my crx w/b16
hey whats up guys, well i was driving today and i was mashing out on a freewat onramp annd i was on 4th gear at around 6-7000 rpm and my car started to feel like it was sputtering and lagging, like it was choking out on fuel or something, i was wondering if any of you guys ever had this happen to you? and if so what can it be?
Old Apr 24, 2004 | 06:24 AM
garlic jr's Avatar
Default Re: I need help with my crx w/b16 (91b16acrx)
u probably need to check the timing bad...that may be detonation i have had similar problems with my top end after advancing to much...
back it down a few degress but be sure to jump the ecu harness first. nad use a timing light
Old Apr 25, 2004 | 03:06 AM
91b16acrx's Avatar
Default Re: I need help with my crx w/b16 (garlic jr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">u probably need to check the timing bad...that may be detonation i have had similar problems with my top end after advancing to much...
back it down a few degress but be sure to jump the ecu harness first. nad use a timing light </TD></TR></TABLE>
funny you say that because i just adaveanced my timing to 18 degrees, it was back at 14 before i changed it, well it doesnt sputter all the time, just maybe twice when i was taking it hard, felt like the motor was choking or something.
if it was detenation at the high end, will it happen all the time? because i tested out the car a coupel times today and it didnt have that probelem
Old Apr 25, 2004 | 03:28 AM
REX VT's Avatar
Change plugs , check iginition wires for spark jumping
Old Apr 25, 2004 | 04:02 AM
ham's Avatar
ham
do you have a stock high mileage fuel pump? it might be exactly what it feels like- 'choking'
Old Apr 25, 2004 | 07:10 AM
garlic jr's Avatar
Default Re: I need help with my crx w/b16 (zcnos)
yeah change the fuel filter and fuel pump probably. my friends crx si was running a gs-r fuel pump with his b16 ef-9
Old Apr 26, 2004 | 12:23 AM
91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">yeah change the fuel filter and fuel pump probably. my friends crx si was running a gs-r fuel pump with his b16 ef-9 </TD></TR></TABLE>
thanks for the insight guys, i think i might do that, i am running my stock hf fuel punp, and yes its high milage
Old Apr 26, 2004 | 05:51 AM
91b16acrx's Avatar
bump
Old Apr 26, 2004 | 07:50 AM
spaceman's Avatar
it could be lots of things,do a search i have responded to a hundred or so of these problems..good luck
Old Apr 26, 2004 | 01:31 PM
91b16acrx's Avatar
Default Re: I need help with my crx w/b16 (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">it could be lots of things,do a search i have responded to a hundred or so of these problems..good luck</TD></TR></TABLE>
thanks, haha stupid crx have so much problems
Old Apr 26, 2004 | 01:54 PM
crxirex's Avatar
My rex does the same thing, I used some gas cleaner crap every fill up on gas now, and it seems to be helping out. I am at 16deg.
Old Apr 26, 2004 | 02:39 PM
spaceman's Avatar
the crx chasis is good,its just when it comes to swaps you gotta do everything right,then you gotta get that motor tuned properly
Old Apr 26, 2004 | 03:52 PM
B2FiNiTY's Avatar
Definately change the distributer cap and rotor, spark plugs and wires if you haven't recently. Also fuel filter too.
Old Apr 26, 2004 | 03:55 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: I need help with my crx w/b16 (B2FiNiTY)
Id say leave it alone unless it happens again. same thing happened to me about two weeks ago, i down shifted and the motor kept bogging, I pulled to the side of the freeway and waited two secs and restarted the motor and everything has been just fine since then
CivicVX94
Jan 30, 2006 08:42 PM
PAsol_er
May 23, 2005 05:05 PM
hatchinprogress
Jan 7, 2005 10:06 AM
jkcrx
May 22, 2003 12:17 PM
SpeedMonkeyRacing
Nov 11, 2002 05:37 PM
