injectors and trotte body's
Hi All,
I was just wondering if there would be any difference good or bad if i swapped the injectors from my 1.5 civic vti for a set of H22a injectors??
Also would swapping trottle body's with the H22a one make any difference??
Thanks people
Thanks people
the h22a throttle body is 60mm so it is an improvment, but unless you have a port match IM i doubt you will se much, and on the injectors, i know some of the prelude injectors are a different type then B an D series injectors, i think you can easily convert them but not sure, and im not 100% but i do think that they are alittle bigger then the D series injectors, but its not gona help you unless you have other significant mods and dyno time
BlackCRX
Aug 22, 2007 04:23 PM
Turbohatch
Oct 3, 2001 10:36 AM
