squeaking noise in engine
Old Apr 23, 2004 | 01:11 PM
OneFire's Avatar
Default squeaking noise in engine
The noise seems to be coming from the timing belt area, anyone know why it would be doing that? thanks
Old Apr 23, 2004 | 01:13 PM
Blindstuff's Avatar
Default Re: squeaking noise in engine (Eg_Egg)
My distributor made squeaking noises for about its last 50 kms of life, give that a check
Old Apr 23, 2004 | 01:34 PM
riceisnicenv's Avatar
Default Re: squeaking noise in engine (Blindstuff)
my alternater belt was squeeking... i bought some belt treatment and fixed that real quick... no more squeeking
Old Apr 23, 2004 | 01:40 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: squeaking noise in engine (riceisnicenv)
could be H2O pump also...
it's too hard to pin point a noise in the engine.....but check belts first.
Old Apr 23, 2004 | 02:55 PM
rexandfx's Avatar
Default Re: squeaking noise in engine (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">could be H2O pump also...
it's too hard to pin point a noise in the engine.....but check belts first.</TD></TR></TABLE>
Yup, if it's aloud sqeal then it's more than likely your waterpump.
But if it just a sqeak then (dress) the pulleys and the <U>underneath</U> side of your belts, You should do this anyways. It helps your belts stay plyable.
Old Apr 23, 2004 | 02:59 PM
SOHC4life 96's Avatar
Default Re: squeaking noise in engine (rexandfx)
sounds like one of the belts, dont hold me to it though, my engine squeaks as well. however i just got my timing belt replaced about a month and a half ago. just get some belt treatment and if that doesnt work get them replace(your car will thank you)
Old Apr 23, 2004 | 04:00 PM
stew18564's Avatar
belt treatment should fix it, if its not that then check your water pump
mreed
Jan 16, 2023 09:02 PM
raybo
Jul 8, 2012 11:14 AM
Sivik
Jun 26, 2005 03:14 PM
ramz7887
May 12, 2003 03:58 PM
timbuktu
Mar 19, 2002 05:48 PM
