Are type R valvesprings and retainers strong enough for S2S2's?
Old Apr 23, 2004 | 11:06 AM
JsNA99si's Avatar
Default Are type R valvesprings and retainers strong enough for S2S2's?
I am looking for some valvesprings and retainers and found a seller with type R valvesprings and wanted to see if they are strong enough?
thanks
Old Apr 23, 2004 | 01:35 PM
DEVIOUS_EG*'s Avatar
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (baby99si)
i've seen it done.. but.. don't do it.. later on you'll run into some problems (coil bind) either run the skunk's.. or you can purchase some portflow inners and use the ITR outer's (springs).... or try Rocket's stuff ... hope that helps.....
Old Apr 23, 2004 | 01:57 PM
92TypeR's Avatar
FSAE
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (DEVIOUS_EF*)
Retainers yes, valvesprings not exactly. They will run perfectly fine under VTEC, but once you get that 12.2mm lift in VTEC your springs will have a chance of binding, which isn't what you want. I wouldn't risk it when perfectly able valvetrain components can be had for under 300 for a complete set.
Old Apr 23, 2004 | 02:22 PM
JsNA99si's Avatar
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (92TypeR)
yeah, i see waht you guys are saying. Thanks
Old Apr 23, 2004 | 02:32 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">Rocket's stuff</TD></TR></TABLE> = JG Stuff
Old Apr 23, 2004 | 04:38 PM
Rocket's Avatar
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (SoCalude98)
Really? Don Corleone? Anyways wrong.
Back to some helpful info. Cams such as Skunk Stage 2's, JUN3's Crower 3's have extremely harsh ramps and require more than stock ITR and GSR spring pressure to adequately control the valve motion. Otherwise all sorts of bad things will happen like pulling the valve thru the retainer, hammering the valve job, stem tip mushrooming, cam wear.
Old Apr 23, 2004 | 05:21 PM
smokey2.0's Avatar
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (Rocket)
rocket, will itr intake outer springs, itr retainers, with portflow inner springs be capable of taking on skunk2 stage 2 cams?
Old Apr 24, 2004 | 04:45 PM
Rocket's Avatar
Default Re: Are type R valvesprings and retainers strong enough for S2S2's? (smokey2.0)
Yes, I've seen that set-up work fine to 8700 rpms with similiar cams.
Old Apr 24, 2004 | 04:59 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Really? Don Corleone? Anyways wrong.
buahahahahah
Old Apr 26, 2004 | 09:13 PM
JsNA99si's Avatar
thanks for the info guys
maomaniarocks
Oct 28, 2006 07:49 PM
H22A EG6
Nov 3, 2004 09:11 AM
hybridEj6
12
Jul 2, 2004 08:37 PM
crxste
Dec 4, 2003 11:12 AM
Direct Motorsports
Jan 24, 2003 07:08 AM
