problem with vtec (HELP LONG READ)
Old Apr 23, 2004 | 08:57 AM
Mr HYDE's Avatar
Default problem with vtec (HELP LONG READ)
ok heres the problem me and my friend are haveing. he has a 97 obd2 itr motor in his 94 teg ls obd1. we used an obd1 harness and switched the dizzy adn ecu to obd1 also. wired it all up for vtec soiliond and knock sensor and had the ecu chipped for the motor now the ecu is a pr3 -j01 so i dont know if thats teh problem its for a b16 obd1 but. the obd2 motor has no vtec oil pressure swtich. and i had a friend use an obd1 ecu in his obd2 car and he threw the same check engine light we are (code 22) for vtec oil pressure and his vtec still turned over. we took the wire for the oil pressure and grounded out after that we took it for a ride vtec turned over once then wouldnt anymore. so we swtiched ecu with my spoon p72 and vtec turns over again but sometiems shuts off but will turn over more then his ecu. his ecu will only turn over after u turn the car off adn start it then take it for a drive turns over once then thats it. we cant figure out why vtec will not be constant. we thionk the ecu can be the problem with not beiing chipped wrong cuz its a custom program or the ecu is fucked but why would it still turn off sometimes with my ecu ? adn the only check engine is 22
Old Apr 23, 2004 | 09:28 AM
Mr HYDE's Avatar
Default Re: problem with vtec (gen5hatch)
ttt for help
Old Apr 23, 2004 | 10:39 AM
Mr HYDE's Avatar
someone here has to have had a problem like this HELP
Old Apr 23, 2004 | 10:50 AM
spaceman's Avatar
maybe the system for the vtec is off or not right,maybe theres a wire problem somewhere..im not sure
Old Apr 23, 2004 | 11:00 AM
Mr HYDE's Avatar
Default Re: problem with vtec (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">maybe the system for the vtec is off or not right,maybe theres a wire problem somewhere..im not sure</TD></TR></TABLE>
? its only one wire for the vtec soliond adn 2 for oil pressure but we dont haev oil pressue on the obd2 motor
Old Apr 23, 2004 | 11:32 AM
spaceman's Avatar
whatever dood...im talkin about the part that turns the vtec on
Old Apr 23, 2004 | 11:56 AM
Mr HYDE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">whatever dood...im talkin about the part that turns the vtec on</TD></TR></TABLE>
oh we checked that forgot to mention that is working
Old Apr 23, 2004 | 12:38 PM
Mr HYDE's Avatar
bump
Old Apr 23, 2004 | 05:24 PM
Mr HYDE's Avatar
BUMP
Old Apr 23, 2004 | 07:39 PM
Mr HYDE's Avatar
Default Re: (gen5hatch)
theres gotta be someone with a problem like this. it doenst shut off anymore when running the p72 spoon ecu but its mine so ill be taking it back but we put a p28 chipped ecu in and it turned off in 4th gear that seems tto be the spot after 4th it shuts off
Old Apr 23, 2004 | 10:44 PM
TIRENECK's Avatar
you just answered you problem.
Old Apr 24, 2004 | 08:52 AM
Mr HYDE's Avatar
Default Re: (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">you just answered you problem.</TD></TR></TABLE>
how u figure it still shuts off and its the wrong ecu plus its MY ecu and i need it abck but it still doesnt work with a p28 so how did i answer my problem
Stephdavis18
Jan 20, 2007 11:55 PM
94IntegraLs04
Aug 31, 2005 07:53 PM
Boost2NA
Sep 14, 2004 02:44 PM
Project92Hatch
Apr 17, 2003 10:52 AM
