AC on a GRS swap
Old Apr 23, 2004 | 06:03 PM
acura delsol's Avatar
Default AC on a GRS swap
I have a GSR swap into a '94 Del Sol, and i need ac. I have herd that the DOHC del sol vtec bracket is what i need, along with some tensioner. So i called Honda to see how much it was. He had no clue as to what a DOHC was, and quoted me $30. I knew this was wrong so i didn't order it. So does anybody know where i cas get one, that will for sure work, along with a tensioner, or does anybody know any part numbers for the right one?
Old Apr 23, 2004 | 06:12 PM
Kendall's Avatar
You will need the components from the GSR engine. Not the components from the Del Sol VTEC.
Old Apr 24, 2004 | 06:45 AM
Default Re: (Kendall)
I have heard that it wont work that way, because the lines for the ac wont connect to the GSR compressor.
Old Apr 24, 2004 | 07:23 AM
mmuller's Avatar
Mad Scientist
Default Re: (acura delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura delsol &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that it wont work that way, because the lines for the ac wont connect to the GSR compressor.</TD></TR></TABLE>
your right, they wont, the AC line connectors point a different way than on integras.
you could swap your civic lines for integra ones
Old Apr 24, 2004 | 09:29 AM
miahmouse's Avatar
Default Re: AC on a GRS swap (acura delsol)
to physically attach the compressor (del sol) to the motor you'll need the del-sol-vtec compressor mount. don't have part numbers. can get it on classifieds...
edit ... here you go
http://www.hondaautomotivepart...EC%29
Modified by miahmouse at 7:14 PM 4/24/2004
bossman032
18
Dec 23, 2008 03:35 PM
nighthawkgsr
Dec 15, 2005 06:35 PM
97civicsedan
May 21, 2005 07:05 PM
DaeTaM3
May 14, 2004 09:44 PM
