dyno from my ITR
I've never posted over here before but figured you guys would like to see some more dyno's.
Car was originally set up for turbo but I sold the turbo setup and threw in the ITR header, pistons and VAFC....now we are NA all the way.
We couldnt get any more fuel into it with out running silly fuel pressure so needless to say bigger injectors are in my future.
set up:
Motor and Drive train
B18C5 block Golden Eagle Sleeved
Stock ITR head and cams
Endyn 12.2:1 comp. strutted pistons 84.5mm
Crower Rods
Apexi VAFC
ARP Head bolts
Endyn Ported Intake manifold
Comptech Ice Box
Mugen Thermostat
Mugen Oil Cap
DC Sports short shifter
JUN lightweight flywheel
Clutchmaster stage 3 Clutch
GSR 5th Gear (172mph top speed)
MSD High Power Anti Vibration Coil and Distributor cap
LHT Performance Engine Damper
Endyn Catch Can
Fluidyne Radiator
Exhaust System
JDM 98 spec 4-1 header (un ported)
Test Pipe
Mugen Twinloop Exhaust
Fuel
Prelude 91-96 injectors
B&M fuel pressure Reg.
Walboro 255lph fuel pump
Apexi VAFC
Engine Management
JDM 98 spec ITR ecu
J&S v2 Safeguard
Suspension/Brakes
Acura NSX front Calipers
Acura Legend 28mm front rotors
LHT Performance Master Cylinder Brace
Mugen Sport Type R Coilover system
Mugen 26mm rear sway bar
Mugen Front and rear tower bars (authentic)
scott
set up:
Crower Rods
Apexi VAFC
ARP Head bolts
Comptech Ice Box
Mugen Thermostat
Mugen Oil Cap
Endyn Catch Can
Fluidyne Radiator
Exhaust System
Test Pipe
Fuel
Apexi VAFC
Engine Management
JDM 98 spec ITR ecu
J&S v2 Safeguard
Suspension/Brakes
scott
Damn, very good numbers considering the stock head and cams.
A little bit of headwrok and a nice cam/spring/retainer package and that thing will be a monster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch »</TD></TR><TR><TD CLASS="quote">Damn, very good numbers considering the stock head and cams.
Nice!
Nice!
thanks for the kind word everyone
The car is a constant work in progress, I will be returning to the dyno in the next couple of weeks with some more goodies.
scott
scott
»</TD></TR><TR><TD CLASS="quote">"Strutted pistons" what do you mean by that? Raised pin?
I would like to know.
The easiest way to explain what they look like is that the skirt is not a complete circle. When you see one you will know what I mean. I will try and find a pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AIM:eg6bronze »</TD></TR><TR><TD CLASS="quote">nice numbers ... and only with itr cams ... </TD></TR></TABLE>
That's the part that amazes me the most.
»</TD></TR><TR><TD CLASS="quote">"Strutted pistons" what do you mean by that? Raised pin? I would like to know.
</TD></TR></TABLE>The easiest way to explain what they look like is that the skirt is not a complete circle. When you see one you will know what I mean. I will try and find a pic.
'200whp ain't easy' -true, and there's a lot of work/$ in this setup, but w/a better header, cams, and better engine management/tuning, it's easily there, + some. nice build.
btw Bob, i sent the $ for the 310s.
decent numbers, yes, but did anybody else realize that this motor is 84.5mm w/ 12.2/ c.r.? ITR cams make very good tq numbers, so, i'm not really suprised at the results, the h.p #'s are o.k., but not impressive. this is by no means a dis to this build up, its just that i've seen b18c1's w/11.5/1 c.r. and ITR cams put up those #'s with an 81mm bore. the tq #'s, ....well.....that's a different story. good luck on your progress.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">
decent numbers, yes, but did anybody else realize that this motor is 84.5mm w/ 12.2/ c.r.? ITR cams make very good tq numbers, so, i'm not really suprised at the results, the h.p #'s are o.k., but not impressive. this is by no means a dis to this build up, its just that i've seen b18c1's w/11.5/1 c.r. and ITR cams put up those #'s with an 81mm bore. the tq #'s, ....well.....that's a different story. good luck on your progress.</TD></TR></TABLE>
Im aiming for those number since i only have itr cams aswell ... ive got 11:1 w/ 84mm bore.
I might take some pics of the car tomorrow. I will post em up if I do.
Well I did a header swap already, found a DC Race header and picked that up. We cut the muffler off and attached it to my Mugen exhaust.
Car feels a hell of alot stronger everywhere!!
back to the dyno
scott
back to the dyno
scott
chet
Dec 8, 2004 09:45 AM
