Question on Hondata and 880cc injectors....re: resistor pack
Old Apr 23, 2004 | 04:44 AM
jdub db8's Avatar
Default Question on Hondata and 880cc injectors....re: resistor pack
I do still use the resistor pack when using hondata right, i sat down last night and re-did my harness (new flex loom and tape) as well as changed and fized plugs etc. I also added my resistor pack but then was like....hmmm?
Just wanted to double check my knowledge- Thanks in Advance!!
Old Apr 23, 2004 | 06:18 AM
DaX's Avatar
DaX
Loved
Community Favorite
880's are low impedance therefore yes you will need a resistor pack.
Old Apr 23, 2004 | 09:20 AM
jdub db8's Avatar
Default Re: (DaX)
That was my assumption- Always try to double check things though- ecspecially getting this close to being back together!
Thanks Dax
Old Apr 23, 2004 | 09:31 AM
turbo*s2k's Avatar
Default Re: Question on Hondata and 880cc injectors....re: resistor pack (Jester_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester_Si &raquo;</TD></TR><TR><TD CLASS="quote">I do still use the resistor pack when using hondata right, i sat down last night and re-did my harness (new flex loom and tape) as well as changed and fized plugs etc. I also added my resistor pack but then was like....hmmm?
Just wanted to double check my knowledge- Thanks in Advance!!</TD></TR></TABLE>
You are correct!
wappid
Apr 2, 2005 08:53 PM
hlub29
Dec 5, 2004 11:48 AM
Modern Intellect
May 10, 2004 05:47 AM
DC2NR
Jun 22, 2003 08:35 AM
sporkcrx
Apr 18, 2003 06:27 PM
