Question on Hondata and 880cc injectors....re: resistor pack
I do still use the resistor pack when using hondata right, i sat down last night and re-did my harness (new flex loom and tape) as well as changed and fized plugs etc. I also added my resistor pack but then was like....hmmm?
Just wanted to double check my knowledge- Thanks in Advance!!
Re: Question on Hondata and 880cc injectors....re: resistor pack (Jester_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester_Si »</TD></TR><TR><TD CLASS="quote">I do still use the resistor pack when using hondata right, i sat down last night and re-did my harness (new flex loom and tape) as well as changed and fized plugs etc. I also added my resistor pack but then was like....hmmm?
Just wanted to double check my knowledge- Thanks in Advance!!</TD></TR></TABLE>
You are correct!
You are correct!
