SHOULD I UP MY BOOST FROM 6-7PSI TO?
Old Oct 31, 2001 | 05:43 AM
4dGSR at work's Avatar
Default SHOULD I UP MY BOOST FROM 6-7PSI TO?
should i up my boost from 6-7psi to 10 psi
i have a gsr w/ stock internals (from what i hear 10 psi is a safe number and why not have 30 more whp ...about)
this would require an MSD BTM, ignition, and 310 injectors
is it worth it??? any input.....
ohh i would re-do my exhaust too
Old Oct 31, 2001 | 06:14 AM
LEON's Avatar
Default Re: SHOULD I UP MY BOOST FROM 6-7PSI TO? (4dGSR at work)
I wouldn't advise it. I know a lot of people who are doing it, but any psi without having the appropriate A/F ratio will be damaging. Just make sure that your A/F ratio is OK (i.e. using a wideband O2 sensor). My suggestion is to wait until you get a standalone and tune it or only run at 10psi once and a while, but hey, I'm conservative.
VTC_CiViC's Avatar
Hmm.. I guess my answer would be, why not? I'm sure after a couple 10psi pulls you'll be glad you did Just make sure you have taken all the precatuions you'll need.
Old Oct 31, 2001 | 08:10 AM
dustin's Avatar
Worst case scenario you crack a ring land and get to build the motor. Go for it hehe.
Old Oct 31, 2001 | 08:19 AM
BoostinDC2's Avatar
Default Re: SHOULD I UP MY BOOST FROM 6-7PSI TO? (dustin)
i drove around on 10psi on my stock motor with a 12.2 a/f and it was fine
blackeg
Jun 20, 2011 12:14 PM
broadheadjohn
Apr 15, 2007 11:48 AM
Nisif
Feb 11, 2006 12:35 PM
AznInvasion
Dec 12, 2004 04:14 AM
CRXRageD
Apr 12, 2002 08:38 AM
