turbo,sc psi
Old Apr 23, 2004 | 12:02 AM
out_of_order's Avatar
Default turbo,sc psi
does anyone know if 7 psi for turbo is the same for a s/c...and weather the jackson racing sc or the greddy kit gives out more power on stock boost. thanks
Old Apr 23, 2004 | 12:05 AM
SiR Kid's Avatar
New User
Default Re: turbo,sc psi (gotriceboy05)
COmparing those kits, 7 psi would be about the same, whichever route you go.
When you start doing more, more boost, more other mods, the GReddy kit will outshine the Jackson Supercharger by a long shot, but it still sucks compared to a custom built turbo system.
Old Apr 23, 2004 | 02:09 AM
kshymkiw83's Avatar
Default Re: turbo,sc psi (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">COmparing those kits, 7 psi would be about the same, whichever route you go.
When you start doing more, more boost, more other mods, the GReddy kit will outshine the Jackson Supercharger by a long shot, but it still sucks compared to a custom built turbo system.</TD></TR></TABLE>
That is very true. Custom Turbo system is the way to go.
Old Apr 24, 2004 | 04:47 PM
so would a sc be better if your only running stock booost due to the fast boost on a A6 and they can only rev up to 7000rpm..
Old Apr 25, 2004 | 04:48 AM
SiR Kid's Avatar
New User
Default Re: (gotriceboy05)
Fast boost with a supercharger is a misconception... A correctly sized turbo will spool up just as fast as a supercharger. Hell, the GReddy kit spools well before 3k rpm on a D series... How often do you launch your car to race below 3k rpm?
Old Apr 25, 2004 | 07:22 AM
y49crxsi's Avatar
Default Re: (SiR Kid)
and how often do you go below 4500-5000 rpms when shifting, people say sc for teh low end power, your only there for a second or less, so whats teh point, turbo lag is more like traction control. Turbo is also cheaper, and more efficient. and has more potential.
Old Apr 25, 2004 | 07:49 AM
MooreBoost's Avatar
Default Re: (y49crxsi)
7psi from a turbo will make more power.
I have had two blowers on my Honda's and am building my first turbo car just because I got tired of them. I would go for the turbo.
Old Apr 25, 2004 | 05:11 PM
actually i luach at 1700-2000 rpm....but yah i guess turbo sounds like the way to go...would a custom turbo be "better" (in general) then a greddy turbo for an A6 if im only goin stock boost??
and nice to know that Greddy gets boost before 3k....i didnt kno that...
o yah one more thing....the reason i was considering SC because ive heard alot of people blowing there motor and since i dont have a rev limiter i thought itd be better to SC but correct me if im wrong
Old Apr 25, 2004 | 11:13 PM
crxturboh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotriceboy05 &raquo;</TD></TR><TR><TD CLASS="quote">actually i luach at 1700-2000 rpm....but yah i guess turbo sounds like the way to go...would a custom turbo be "better" (in general) then a greddy turbo for an A6 if im only goin stock boost??
o yah one more thing....the reason i was considering SC because ive heard alot of people blowing there motor and since i dont have a rev limiter i thought itd be better to SC but correct me if im wrong</TD></TR></TABLE>
you can still BLOW ur motor with a S/C its all about Tunning..... check out http://www.homemadeturbo.com they got some crazy **** going on... good HP numbers for a stock internals...but Turbo is the way to go like some dude here said... oh and Turbo LAG was never a problem.. some people use 25,35 shots of nitrous to help on that lag... but just get the right size turbo for ur motor.. you're good to go. I was running a T3 garret turbo on my Soch Vtec.. act stage 3 clutch and some other mods... let me tell u .. once u go turbo u never want to go back.. i sold that car now i got another crx si with LS Vtec.. can't wait to drop a turbo on that one....
guessinthe2000
Jan 7, 2007 12:36 PM
desiromeo812
Jul 31, 2005 10:45 PM
joshcivic00
Jul 24, 2005 11:44 PM
maciek
Feb 21, 2005 09:46 PM
