OIL Pressure gauge?
Old Apr 22, 2004 | 11:17 PM
Super_Eg6's Avatar
Default OIL Pressure gauge?
I in search of a new oil pressure gauge...does anyone have any suggestion...should i get a machnical or electrical?
Old Apr 22, 2004 | 11:44 PM
mmuller's Avatar
Mad Scientist
Default Re: OIL Pressure gauge? (Super_Eg6)
i like mechanical better, more accurate.
but not a lot of people like the idea of running lines into the cabin
Old Apr 23, 2004 | 07:46 AM
evolve's Avatar
Default Re: OIL Pressure gauge? (mmuller)
Where do connect the mechanical gauge to?
Old Apr 23, 2004 | 12:28 PM
SupaTeg's Avatar
Default Re: OIL Pressure gauge? (evolve)
oil pressure switch at the back of the block
Old Apr 23, 2004 | 12:38 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">I in search of a new oil pressure gauge...does anyone have any suggestion...should i get a machnical or electrical?</TD></TR></TABLE>
Autometer mechanical gauge w/ a copper oil line.
Old Apr 23, 2004 | 06:23 PM
mmuller's Avatar
Mad Scientist
Default Re: OIL Pressure gauge? (LSVTEC 91 Civic)
this is how i have mine, if it helps...
Old Apr 23, 2004 | 08:50 PM
Super_Eg6's Avatar
i have a "t" for my LSV oil line...BUT if i have a 3 way joint for oil-line, oil-pressure sensor (oem) and a line for the gauge, will all these connections affect the acutal pressure for the gauge...???
Old Apr 23, 2004 | 10:00 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> i have a "t" for my LSV oil line...BUT if i have a 3 way joint for oil-line, oil-pressure sensor (oem) and a line for the gauge, will all these connections affect the acutal pressure for the gauge...???</TD></TR></TABLE>
no they wont.
Old Apr 23, 2004 | 11:13 PM
mmuller's Avatar
Mad Scientist
Default Re: OIL Pressure gauge? (hybridvteceg)
i advice against putting all those connections on the stock oil pressure switch location on the block.they could easily rattle itself out.
they sell distribution blocks, so just run a line to that.
you can take the stock sensor out since you have a aftermarket pressure gauge
Old Apr 24, 2004 | 12:50 PM
dfoxengr's Avatar
heres my setup. lsvtec and oil pressure gauge, plus stock sensor, all on the firewall.
Old Apr 24, 2004 | 12:56 PM
Casey's Avatar
be careful when using copper tubing on mechanical guages. mine broke at the fitting going into the gauge and leaked all out inside my car. Luckily i caught it and stopped it up. A few days later it started to leak at the fitting on the back of the block and I was down a qt and a half the copper tubing gets fragile with the pressure fitting on it inside the screw on brass fittings so be careful
Old Apr 24, 2004 | 12:57 PM
dfoxengr's Avatar
Default Re: OIL Pressure gauge? (Casey)
yeah i would just use the plastic kind.
Old Apr 26, 2004 | 06:11 PM
Super_Eg6's Avatar
ok coo, i was about to use copper ones but ill just stick with the plastics then...thanks
Old Apr 26, 2004 | 06:12 PM
Banned
&lt;-- has good luck with the copper tubing, doesn't trust plastic oil line, but thats just me...
Old Apr 26, 2004 | 07:39 PM
kur0ryu's Avatar
can't you get an adaptor that goes on the oil filter area that has oil temp/pressure connections? I think greddy has one.
Old May 5, 2004 | 10:48 PM
Super_Eg6's Avatar
Default Re: OIL Pressure gauge? (kur0ryu)
yes i found out that golden eagle has a better one than greddy....group buy is cheaper too...my friend had a greddy one but our local hot rod shop that seems to have all the fittings in the world could not find one that fits so when we calleda GREDDY distbutor, they said they have no idea what the size was, only that it fits the greddy gauge adaptors...
HXMan
Oct 19, 2012 07:00 AM
fryman
Aug 26, 2009 10:42 PM
hondaz6lx
10
Jan 13, 2007 10:43 AM
93_hatch
May 3, 2004 10:20 PM
