Ohm question
Old Apr 22, 2004 | 08:20 PM
RUBZERK's Avatar
Default Ohm question
Is a 2 Ohm dvc sub better than a 4 Ohm dvc sub ???
what is the diff ?????
Old Apr 22, 2004 | 08:23 PM
wowsers's Avatar
Default Re: Ohm question (RUBZERK)
depends on your setup. how many subs. how will they be wired. what kind of amp. how much power can it give in what load?
Old Apr 22, 2004 | 09:15 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Is a 2 Ohm dvc sub better than a 4 Ohm dvc sub ???
what is the diff ?????</TD></TR></TABLE>
No, the only difference is the impedence. The one right for you would depend on your amplifier. "Generally" speaking a two ohm speaker will allow you to extract more power out of your amplifier. A DVC 2 ohm speaker wired in parallel will make a 1 ohm load to your amplifier.
What amplifier do you intend to use? Do you intend to run it in stereo or mono?
Importn2oRacer
Audio / Security / Video
13
Jun 14, 2007 04:45 PM
RossMathis
Feb 12, 2007 05:13 PM
weak_tec
Jun 25, 2005 01:09 PM
diluted
May 22, 2005 04:38 PM
IDriveHonda
18
Oct 9, 2003 05:43 PM
