Amplfier Question
What is the best amp for this sub? I want to keep everything Kicker, so make sure that whatever amp you suggest is Kicker. Thanks
http://www.circuitcity.com/ssm...il.do
Being that it's a 4 ohm sub i believe you will only get half power out of the Kicker 300.1 which would put you right at 150W rms. Right at what the sub can handle continuously. So I wouldn't go any smaller than that. Although there are other amps out there to suit your need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RossMathis »</TD></TR><TR><TD CLASS="quote">Well I have two of these and I was thinking either a 350.2 or 350.4. What do you think?</TD></TR></TABLE>
Oh. Well in that case if you have two then a Kicker 300.1 would be perfect. You can get the other two amps but you're just wasting money. The 350.4 is mainly a door speaker amp. Class A/B i believe. A 300.1 would do just fine as 300W RMS is all that those subs are good for combined.
