need help!!!!
Old Apr 22, 2004 | 06:45 PM
1991dxhatch's Avatar
Default need help!!!!
recently i've done a mpfi conversion anyways today i was driving and my car just shut off and wouldnt start back up. i checked for spark and nothing. it has a brand new distributor so im lost. im getting codes-6,10,13,16. has anyone ever ran in to this or have any ideas.
Old Apr 22, 2004 | 09:48 PM
Redline130's Avatar
Default Re: need help!!!! (1991dxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991dxhatch &raquo;</TD></TR><TR><TD CLASS="quote">recently i've done a mpfi conversion anyways today i was driving and my car just shut off and wouldnt start back up. i checked for spark and nothing. it has a brand new distributor so im lost. im getting codes-6,10,13,16. has anyone ever ran in to this or have any ideas. </TD></TR></TABLE>
6-ECT (Engine Coolant Temp sensor)
10-IAT (Air Intake Temp sensor)
13-Barometric Pressure sensor
16-Fuel Injector
What ecu are you using? That is a wide variation of codes. Did you plug all the everything back into the right place? I would double check too make sure that your wiring is right. Do you have all of your grounds attached?
Old Apr 23, 2004 | 11:10 AM
Default Re: need help!!!! (Redline130)
pm6 everything is hooked up right. the car ran good before it died. i tried another ecu and it still didnt start. im not getting any spark.
Old Apr 23, 2004 | 11:17 AM
Redline130's Avatar
No spark usually means either the coil or ignitor is not working. You did however say that you changed the distributor for a new one. Do you have all the necessary grounds securely attached? Did you get a new OEM distributor, or a reman one?
Old Apr 23, 2004 | 03:51 PM
reman. yes all grounds are hooked up. do you know if there is a seperate ground for the ecu? because today i went back to the car and the ecu light wasnt even flashing?
Old Apr 23, 2004 | 08:49 PM
Redline130's Avatar
Do you have the ground on the thermostat attached?
Old Apr 23, 2004 | 09:21 PM
SunkistRex's Avatar
we had this problem at this place i used to work at, the engine coolant temp sensor was bad, get a new one and it should fire right up
Old Apr 23, 2004 | 11:01 PM
Origin's Avatar
Default Re: need help!!!! (Projekt X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt X &raquo;</TD></TR><TR><TD CLASS="quote">we had this problem at this place i used to work at, the engine coolant temp sensor was bad, get a new one and it should fire right up</TD></TR></TABLE>
so if the coolant temp sensor is bad then the car wont spark? just trying to figure out a problem im having.
Old Apr 24, 2004 | 07:41 AM
SunkistRex's Avatar
Default Re: need help!!!! (Origin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">
so if the coolant temp sensor is bad then the car wont spark? just trying to figure out a problem im having.</TD></TR></TABLE>
i think it prevents the car from turning over, it would sit there and just crank : like da da da da da da... try that make sure its plugged up to
94accordlx1
Mar 25, 2019 10:24 AM
video_voide
17
May 13, 2011 04:37 PM
itrintegra
Oct 3, 2007 02:34 AM
88_lsvtec_hatch
Sep 11, 2006 12:01 PM
1hottEG6
May 6, 2002 01:43 PM
