just broke my lug bolt stud
Old Apr 22, 2004 | 05:57 PM
1hotcivicSi's Avatar
Default just broke my lug bolt stud
how do i fix it i broke it in half i need a new one now ...... how do you take the broken one out and put a new one in ??
Old Apr 22, 2004 | 06:03 PM
dahveed's Avatar
Default Re: just broke my lug bolt stud (1hotcivicSi)
where is it brke from the back or front?
Old Apr 22, 2004 | 06:22 PM
99blackcivicSi's Avatar
Default Re: just broke my lug bolt stud (dahveed)
what kind of car? If it is a 99-00 Si
take wheel off
take rotor caliper off
pull hub out
pound old stud out
put new stud in
Put new wheel bearing in
press hub back on
put rotor back on
put caliper back on
put wheel back on
Thats pretty much the giest of doing the fronts on a 96-00
Old Apr 22, 2004 | 06:59 PM
Default Re: just broke my lug bolt stud (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">what kind of car? If it is a 99-00 Si
take wheel off
pull hub out
pound old stud out
put new stud in
press hub back on
put rotor back on
put caliper back on
put wheel back on
Thats pretty much the giest of doing the fronts on a 96-00 </TD></TR></TABLE>
thanks
Old Apr 26, 2004 | 04:20 PM
aeon's Avatar
so you gotta get a new stud and new wheel bearing?? how much would that cost??
Old Apr 26, 2004 | 05:28 PM
743power's Avatar
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">so you gotta get a new stud and new wheel bearing?? how much would that cost??</TD></TR></TABLE>
you don't nessecarily have to get a new wheel bearing, but there is a good chance it will get damaged while removing the hub, so its good to get one if you can afford it. The bearing is about $60 from honda and the stud is around $4 from honda.
Also, if you dont have a press, you can use a silde hammer to pull off the hub.
Old Apr 26, 2004 | 05:30 PM
MR5sARECOOL's Avatar
Default Re: (x743x)
Get a Helm Manual, it will help, and save your *** many times.
Old Apr 26, 2004 | 06:18 PM
kabaroo's Avatar
you can grind down the stud and slip it in without having to deal woth pressing and whatnot. i did it to mine last summer. no problems yet. and when i say slip it in its not that easy but it worked for me. oh and it was on a del sol.
Old Apr 26, 2004 | 06:20 PM
Default Re: just broke my lug bolt stud (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">you can grind down the stud and slip it in without having to deal woth pressing and whatnot. i did it to mine last summer. no problems yet. and when i say slip it in its not that easy but it worked for me. oh and it was on a del sol.</TD></TR></TABLE>
wait explain what u did exactly
Old Apr 26, 2004 | 09:41 PM
Hornet_Loader's Avatar
Quote, originally posted by kabaroo »
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
wait explain what u did exactly</TD></TR></TABLE>
You could do that, and it would go in easier, but it is a press-fit for a reason. If it goes in easily, it'll come out easily, too. Think about it. If it is loose (in comparison) then it isn't going to carry its share of the load, leaving the other three to do the work. Its your car and your life to do with as you will, but that is a dangerous thing to do, especially on the front wheels. Jim.
As an edit - I'm sorry, I didn't mean to come across as a dink. If the lugs are tight going in, put them in the freezer (or even better, a bath of isopropyl alcohol and dry ice - like, -80F) and if you can, heat up the hub (350F in the oven works great) then they'll fit together a lot easier. Good luck. Jim.
Modified by Hornet_Loader at 12:01 AM 5/2/2004
streetracer_305
18
Jun 20, 2015 01:59 PM
Eucalyptus lude
Apr 24, 2005 11:50 AM
nEoMuGen
Nov 15, 2003 04:17 PM
Mr X
Jul 31, 2003 06:40 AM
InfamousRS
Feb 11, 2002 09:36 PM
