Waterpump decided to go....
Old Apr 22, 2004 | 05:39 PM
Andres-eh2's Avatar
Default Waterpump decided to go....
My waterpump went after my father put some radiator flush in it to "flush" the system. In a couple of weeks i will be doing and LS swap (buying the parts right now) so im not going to change the waterpump on the stock VX motor.
Question
Can i just put silicone or something all over it in the meantime to it doesnt leak? Im not going to use the car everyday...
TIA
Old Apr 22, 2004 | 07:17 PM
Andres-eh2's Avatar
soo many ppl, nobody knows?
Old Apr 22, 2004 | 07:20 PM
-Justin-'s Avatar
Default Re: (Andres-eh2)
explain a little more what happened, is it leaking?
Old Apr 22, 2004 | 07:29 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (B16EH2)
My water pump is leaking also, its leaking out of the weep hole. And it sucks because the coolant is getting on my timing belt and making it squeal like a pig. But I just ordered the whole kit from prostreet. I don't think silicone is going to work, but I guess it worth a try. If you do it make sure you let it sit over night and dry.
Old Apr 22, 2004 | 07:41 PM
Debaser's Avatar
Default Re: Waterpump decided to go.... (Andres-eh2)
Doubt it dude. Silicone won't hold up. If it's pissing out of the weep hole and you're not going to drive it every day, carry a jug or two of water with you and don't go on any long voyages. You'll probably be able to sneak around OK, I have gotten away with it.
It depends on how bad it is. I've taken a water pump out of my Civic with a shattered impeller that was in 6 pieces.
Old Apr 22, 2004 | 08:25 PM
eg crunkmonster's Avatar
Default Re: Waterpump decided to go.... (Debaser)
just carry a lot of water with u and never open the cap when it is hot (u probably already know that one) just reminding u
Old Apr 22, 2004 | 08:27 PM
Andres-eh2's Avatar
yea i think i will try it.
Old Apr 23, 2004 | 10:02 AM
Andres-eh2's Avatar
anyone else?
tag0617
Apr 17, 2011 11:09 PM
klion22
May 27, 2008 12:28 PM
DarkBB4
Mar 18, 2005 11:26 AM
Seye
Mar 28, 2004 03:26 PM
DRKSol
Jul 6, 2003 10:52 PM
