D series bottom ends...
Old Apr 22, 2004 | 05:33 PM
6thgen4u2nv's Avatar
Default D series bottom ends...
whats up, im going to build up a d series beast, I have an a6 block right now, or should I just use the z6 block? im looking to run boost...
Old Apr 22, 2004 | 06:02 PM
DonPapadapolis's Avatar
Default Re: D series bottom ends... (6thgen4u2nv)
try searching
Old Apr 22, 2004 | 06:06 PM
drewbie's Avatar
Default Re: D series bottom ends... (DonPapadapolis)
get a turbo kit
and then you can run boost
Edelbrock makes about 170 HP with stock bottom end
Old Apr 22, 2004 | 06:32 PM
Eee Pee's Avatar
Z6 block and pistons are a lower compression number.
Old Apr 22, 2004 | 06:34 PM
BauleyCivic's Avatar
Risky Business
Default Re: D series bottom ends... (Eee Pee)
Use the Z6 block for the lower compression as Eee Pee stated...there are several people on this board pushing 250 WHP on stock internals (with a shitload of tuning though). If you want to run more than 10-12 psi, i'd suggest getting forged pistons, eagle rods, arp head studs and rod bolts, and think about sleeving your block.
541tejeda
Northwest (Sales)
May 7, 2014 11:09 AM
xxwhixx
Jul 13, 2009 06:39 PM
notburton06
Sep 23, 2008 07:21 AM
civicjoe
Apr 7, 2008 11:04 AM
JDMCRX
Jul 16, 2003 11:08 AM
