E-Brake Light stays on Even with E-Brake lever down
My e-brake light on the cluster stays on even when i release the e-brakes. How do i fix this problem? Anybody else experienced this before?
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo »</TD></TR><TR><TD CLASS="quote">check your brake fluid. If it is low the light stays on.</TD></TR></TABLE>
Thanks for all the quick response.
I gotta go take a look at the fluid level later on.
The light turned on right after i hit a small bump so i thought probably the e-brake cable got pulled just enough to light it up.
I'll let you guys know after i check the fluid
should there be a sensor right under the brake handle, under your center consule...
that is your best bet to find the answer..
it is some kind push switch.. so it could be jammed causing the closed circuit for the e-brake to seem on, as if you've pulled it...
if your not understanding this.. im/pm me, and remove your center consule..
if you are still running drums...you had a wheel cylinder blow. the fluid level is low from constantly losing the fluid. you will need a new wheel cylinder, and a set of rear shoes since they are likely contaminated from the fluid leak.
teh electrical aspect of a short or the switch being bad is highly unlikely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project91CRX »</TD></TR><TR><TD CLASS="quote">I have disc brakes. No drumsl. Yea, it turns out that my brake fluid was low (Havent really kept my eye on it) Filled it up and lights gone now.</TD></TR></TABLE>
Easiest/cheapest solution.
Z7
10
Aug 6, 2006 01:17 PM
