Wiring an o2 Simulator, in a h22 swap
Ive seen different threads where kids have wired the o2 sim by the ecu, the instructions i have gotten from o2simulator.com kind of show a diagram that looks as if it should be under the car where the o2 use to be, check this pic out, ANY HELP would be appreciated
the color of my wires on my o2 are black black green white....can anyone name these wires as to which is what....as ground, power, signal....
HELP MY CAR IS RUNNING LIKE SH*ATTT!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ddogz15 »</TD></TR><TR><TD CLASS="quote">the color of my wires on my o2 are black black green white....can anyone name these wires as to which is what....as ground, power, signal....
those wire colors are for the oxygen sensor it
you need the harness wire colors cause the wire the oxygen sensor up differently on different models
</TD></TR></TABLE>those wire colors are for the oxygen sensor it
been tryin to wire this thing all night, this is what ive been matchin up
1) I cut off the o2 sensor
2) then i spliced the remainin wires after the plug
3) I matched up the wires in this sequence....
--White o2 Sim - White wire o2 sensor
--Red o2 Sim - Black 12V power wire
--Black o2 Sim - Green Ground Wire
4) Black whire after plug has no home??
5) Ive got a feeling i mix matched some colors here, becuase an obviouse was that the LED didnt blink haha, SOMEONE help if u see a mis match
mugenhatch92
Aug 28, 2004 01:27 PM
