No Memory in newly installed player
I am new to any of this stuff, but the other day I swithed out my wife's original radio/tapeplayer from her 94 civic hatchback and I put in a newer Pioneer radio/tapeplayer that I had laying around. Anyway everything is running smoothly except the fact that the new player won't remember any of the presets that I change. Every time you turn off the car and turn it back on the Bass, Treble, radio presets, clock, etc. go back to their original settings. I know that this is probably an easy fix but I am just not seeing it. Any help be soooooo appretiated.
* LUKE *
Modified by indie301 at 8:29 PM 4/22/2004
* LUKE *
Guest
Posts: n/a
you need to check your wiring...there should be two power wires... red and yellow... yellow needs to go to a constant power to keep the settings active...whereas red goes to ignition...to power the rest of the radio when the car is on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl »</TD></TR><TR><TD CLASS="quote">you need to check your wiring...there should be two power wires... red and yellow... yellow needs to go to a constant power to keep the settings active...whereas red goes to ignition...to power the rest of the radio when the car is on.</TD></TR></TABLE>
Exactly ,on the newer Pioneers every wire is marked so no confusion.
