No Memory in newly installed player
Old Apr 22, 2004 | 10:06 AM
indie301's Avatar
Default PLEASE HELP!!! No Memory in newly installed player
I am new to any of this stuff, but the other day I swithed out my wife's original radio/tapeplayer from her 94 civic hatchback and I put in a newer Pioneer radio/tapeplayer that I had laying around. Anyway everything is running smoothly except the fact that the new player won't remember any of the presets that I change. Every time you turn off the car and turn it back on the Bass, Treble, radio presets, clock, etc. go back to their original settings. I know that this is probably an easy fix but I am just not seeing it. Any help be soooooo appretiated.
* LUKE *
Modified by indie301 at 8:29 PM 4/22/2004
Old Apr 22, 2004 | 10:55 AM
PlastikOwl
Guest
Posts: n/a
Default Re: PLEASE HELP!!! No Memory in newly installed player (indie301)
you need to check your wiring...there should be two power wires... red and yellow... yellow needs to go to a constant power to keep the settings active...whereas red goes to ignition...to power the rest of the radio when the car is on.
Old Apr 22, 2004 | 12:15 PM
Skip01's Avatar
Default Re: PLEASE HELP!!! No Memory in newly installed player (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">you need to check your wiring...there should be two power wires... red and yellow... yellow needs to go to a constant power to keep the settings active...whereas red goes to ignition...to power the rest of the radio when the car is on.</TD></TR></TABLE>
Exactly ,on the newer Pioneers every wire is marked so no confusion.
rugimpy
Mar 18, 2010 06:25 AM
madmortar
Audio / Security / Video
May 13, 2008 12:23 PM
super60
May 27, 2006 08:27 AM
PINKS
Jan 9, 2006 11:59 AM
teggymabob
Jun 10, 2003 03:47 PM
