went to track, kinda disappointed
i just got back today at the track and hit a best time of 13.812 @ 104.59 on pretty bald street tires. It was @ 10psi and i dyno @ 265whp. Have some boosting problems thats why its not making much power. Tire pressure was @ 28 in the front and 30 in the back, Koni set to the stiffest. What do you guys think? i know im making hellllllllllla little power and even stock gsr make around that. What do you guys think i have to improve on?
R/T ... .171
60ft ... 2.301
330ft ... 6.052
1/8 ... 9.074
mph ... 83.13
1000 ... 11.653
1/4 ... 13.812
mph ... 104.59
b18a1 w/ b16 head
81.5mm endyn 9:1 rw
eagle rods
act xtreme 4 puck
14lbs flywheel
t3/t4 ar63 57 trim
hks 40mm wastegate
drag 3 manifold
greddy type r bov
2.5 downpipe to 3 thermal
720cc greddy
hondata 2b w/boost
aem fuel rail
sx fpr
walbro 255lph pump
itr IM
skunk2 cam gear
spearco intercooler
arp head bolts
arp rod bolts
jg tb
energy suspension
prothane inserts
koni yellow
ground control coilover
R/T ... .171
60ft ... 2.301
330ft ... 6.052
1/8 ... 9.074
mph ... 83.13
1000 ... 11.653
1/4 ... 13.812
mph ... 104.59
b18a1 w/ b16 head
81.5mm endyn 9:1 rw
eagle rods
act xtreme 4 puck
14lbs flywheel
t3/t4 ar63 57 trim
hks 40mm wastegate
drag 3 manifold
greddy type r bov
720cc greddy
hondata 2b w/boost
aem fuel rail
sx fpr
walbro 255lph pump
itr IM
skunk2 cam gear
spearco intercooler
arp head bolts
arp rod bolts
jg tb
energy suspension
prothane inserts
koni yellow
Heres my suggestion nice and simple
1) Go get some Drag Radials
2) Turn the boost up, 10 psi with Forged piston/Rods Time for some power.
3) Go to the track and practive your 60 ft
Once you've got that down
4) make some clean passes and I garuntee you'll be satisfied.
I mean you couldn't have expected much going to the track on bald street tires could you? And what boosting probs are you having?
my boosting problem is when i up the boost to about 19lbs it doesnt hit full boost till redline and its not making the power its suppose to. i have to replace the manifold and wastegate to get this fixed
