car wont heat up!
Old Apr 22, 2004 | 02:00 AM
a1320honda's Avatar
Default car wont heat up!
i know most people have a problem with over heating, but, i dont. my car heats up fine, but when i get on it like on the freeway and get up around 90 to 100 or so, the temp drops all the way down, and then stays down the rest of the time. W T F. is my water pump just working that good or whats the deal. is the thrmostat not closing? what do you guys think. i have a 92 hatch with the jdm d15b vtec. and actualy it kinda takes forever to heat up. i think its the thermostat, but just want to see what you guys think.
Old Apr 22, 2004 | 02:04 AM
mycivicstoo(s)low's Avatar
Default Re: car wont heat up! (a1320honda)
I'd go with your idea, check that thermostat. It's really cheap, try that first.
Old Apr 22, 2004 | 04:38 AM
ABK's Avatar
ABK
Default Re: car wont heat up! (mycivicstoo(s)low)
Most likely thermostat
Old Apr 22, 2004 | 04:47 AM
Kista20's Avatar
your thermostat is stuck open. Check your heater when your car is warmed up, if it doesn't get hot theres your problem. They're designed this way when they do fail so it won't overheat. But most times they get stuck closed and it overheats.
Old Apr 22, 2004 | 04:57 AM
Jimmy's Avatar
Global Moderator
Default Re: car wont heat up! (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">Most likely thermostat</TD></TR></TABLE>
Old Apr 22, 2004 | 02:28 PM
a1320honda's Avatar
Default Re: car wont heat up! (Usdmdc2)
ok all the hoses are hot. the bottom hose to the rad. is and so is the top to the rad. not warm, friggin hot.
Old Apr 22, 2004 | 04:24 PM
a1320honda's Avatar
anyone?
Old Apr 22, 2004 | 05:41 PM
m3dia_lab's Avatar
sounds like this is a good thing to me??
Old Apr 22, 2004 | 05:48 PM
Kista20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kista20 &raquo;</TD></TR><TR><TD CLASS="quote">The way a thermostat is designed if it sticks it's actually supposed to be stuck open but most of the time it doesn't work that way. Your thermostat is always closed when the coolant isn't at normal operating temp. the hot coolant stays inside the engine, as the engine gets up to temp. the thermostat allows the coolant to escape into the radiator bringing fresh cool coolant back into the engine. While the thermostat is stuck closed it does not allow fresh cool coolant into the engine, i.e. overheating. When it's stuck open the opposite happens and the coolant does not get warm i.e. heater does not blow hot air.
that was taken from another post I had a hand in.
dude a thermostat is like $10-$15 for a honda one, Have you tried running the heater, does it get hot like it should? I had a friend who went through 3 thermostats till he finally got off his cheap *** and got an oem one, his kept getting stuck closed though. I would just go buy a thermostat and say goodbye to over-cooling. Oh and your car is most efficient at 185 degrees. It will not perform as good too cold or too hot.
Old Apr 22, 2004 | 06:06 PM
a1320honda's Avatar
Default Re: car wont heat up! (Kista20)
it doesnt get as hot as it does when the temp gauge reads normal. but still blows hot air
Old Apr 22, 2004 | 07:03 PM
ABK's Avatar
ABK
yeah if both of your hoses are hot as hell it doesn't meen that your thermostat is fine. It's prolly stuck open just replace it I almost 100% guarntee it's it.
Old Apr 29, 2004 | 09:08 PM
FlexW99's Avatar
bumpity..
having a very similar problem with the accord. Car reads on temp guage that its hot...yet blows cold...doesnt overheat.
Think thermo also?...
Old Apr 29, 2004 | 10:25 PM
FlexW99's Avatar
Default Re: car wont heat up! (FlexW99)
Touge Tuning
Jun 27, 2006 06:17 PM
GDM93Si
10
Jun 11, 2006 12:25 PM
jmkc
Nov 5, 2005 09:24 AM
rdeezy25
May 4, 2005 04:51 PM
dustinsterk
Jan 5, 2004 11:56 AM
