what a/f ratio for boosted wot? what voltage on O2 is that?
Old Oct 30, 2001 | 05:59 PM
Jared's Avatar
Default what a/f ratio for boosted wot? what voltage on O2 is that?
Just wondering what to shoot for. 13:1 too lean? 12.5? this is for wot on a 9:1 c/r turbo GSR motor. will be street driven. And whatever ratio is best, what voltage would that approximate to on a 0-1V O2 sensor?
thanks,
Jared
Old Oct 30, 2001 | 10:00 PM
98hx99b18c's Avatar
Default Re: what a/f ratio for boosted wot? what voltage on O2 is that? (Jared)
Jared, not sure on voltage but usually on a boosted car, you want to see around 12.5, 13.0 is ok but might be getting a bit lean.
Old Nov 15, 2001 | 04:40 PM
BoostinDC2's Avatar
Default Re: what a/f ratio for boosted wot? what voltage on O2 is that? (98hx99b18c)
i think 1 is stoich and <1(less) is rich and >1(greater) is lean
Old Nov 15, 2001 | 04:50 PM
dustin's Avatar
Default Re: what a/f ratio for boosted wot? what voltage on O2 is that? (BoostinDC2)
No, .5 is stoich. The O2 does not give anything out over 1v.
You probably want around .92 volts coming from the O2 for safe boosting. It is highly inaccurate though, but you know that.
Dustin
Old Nov 15, 2001 | 05:04 PM
JM Performance's Avatar
Default Re: what a/f ratio for boosted wot? what voltage on O2 is that? (dustin)
what about ratio? when you get your engine tuned what should you aim for? 12.5?
Old Nov 15, 2001 | 05:08 PM
dustin's Avatar
Default Re: what a/f ratio for boosted wot? what voltage on O2 is that? (00SilverLS)
12.5 is safe.
Old Nov 15, 2001 | 06:08 PM
ArizonaTurbo's Avatar
thanks,
Jared
12.0 is a perfect A/F ratio!
AGENT 99
Mar 5, 2006 09:46 AM
nsxjr2
Aug 1, 2004 04:53 PM
speed
Nov 19, 2002 04:28 PM
Smashback
Jan 22, 2002 08:49 PM
