idle problems and misfiring
Old Apr 21, 2004 | 03:20 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default idle problems and misfiring
well i finally got my car painted and out on the road, but now im aving engine problems, the car idles fine then it will dip down, then dip down again,it seems as it if is misfiring or something, it is only in the lower rpms.. i replaced the spark plugs before and it took care of it for about a month and then came back, what could i do now? any way i can do a check or something on it?
Old Apr 21, 2004 | 05:24 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: idle problems and misfiring (coptzer)
Have you checked and/or changed the wires, cap and rotor as well? Maybe your wires are loose. Make sure they are on tight. I've had the wire come loose form the cap before on one of my previous cars.
Old Apr 21, 2004 | 06:09 PM
Audi A4's Avatar
Default Re: idle problems and misfiring (Gee3)
excatly... check all your fittings.. also check for vacumm leaks
Old Apr 21, 2004 | 06:44 PM
Default Re: idle problems and misfiring (DRAG lll INTEGRA)
checked for vacuum leaks and also all the wires are on tight, b4 i bought the car the guy put a new iginitor in the dist, i thought he woulda got new plug wires, but im not sure now, maybe ill get them first
oh and a pic of my car
Modified by coptzer at 10:57 PM 4/21/2004
Old Apr 21, 2004 | 07:58 PM
m R g S r's Avatar
Looks good, what color is that?
Old Apr 21, 2004 | 08:10 PM
IN VTEC's Avatar
When the rpm's drop, does it feel like the engine stumbles briefly, intermittently and rather harshly?
Old Apr 21, 2004 | 08:28 PM
Lastgsr's Avatar
Default Re: idle problems and misfiring (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">When the rpm's drop, does it feel like the engine stumbles briefly, intermittently and rather harshly?</TD></TR></TABLE>what could it be if it does?
Old Apr 21, 2004 | 08:47 PM
IN VTEC's Avatar
Default Re: idle problems and misfiring (Lastgsr)
Lean misfire condition is the first thought that comes to mind. I'd check the logged fuel trims.
Old Apr 21, 2004 | 08:49 PM
Integra4lyfe's Avatar
I have the same problem. I know it's a vaccum leak because when I take off my intake and put my hand over it, the car still runs. I can actually hear where the air is getting sucked in (in my case the intake manifold gasket). Vaccum leaks are notorious with Hondas, check that next
Old Apr 21, 2004 | 08:52 PM
Default Re: idle problems and misfiring (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, what color is that?</TD></TR></TABLE>
its melbourne blue metallic
also i thought it might be a vacuum leak, but it only does it off and on, not something thats all the time, when i get on it its not sluggish and it still rips through redline
also when it happens it does feel like it stumbles briefly intermittenly and harshly, would fuel injector cleaner and new fuel filter help, its either spark or fuel and i cant figure it out
Old Apr 21, 2004 | 11:00 PM
alfaaay's Avatar
Default Re: idle problems and misfiring (Integra4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem. I know it's a vaccum leak because when I take off my intake and put my hand over it, the car still runs. I can actually hear where the air is getting sucked in (in my case the intake manifold gasket). Vaccum leaks are notorious with Hondas, check that next </TD></TR></TABLE>
That's a pretty nifty test. I'm gonna try that on my car because I've been having a slight idle problem too.
Old Apr 22, 2004 | 08:47 PM
Default Re: idle problems and misfiring (alfaaay)
i dont think its an idle problem, would new plug wires be the answer, because new plugs fixed it for about a month?
Old Apr 22, 2004 | 08:54 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">
also when it happens it does feel like it stumbles briefly intermittenly and harshly, would fuel injector cleaner and new fuel filter help, its either spark or fuel and i cant figure it out </TD></TR></TABLE>
Had the same problem. Changed everything. New ignition, FPR, plugs, fuel filter, ignitor, coil, cap, rotor, injectors. Didn't think of changing the wires becuase they were only about 6 months old. At least when I finally got it running right I had brand new everything and a bunch of spare parts. Accel
Old Apr 22, 2004 | 09:33 PM
alfaaay's Avatar
Default Re: idle problems and misfiring (Sack Master)
So are you saying it was the wires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">
Had the same problem. Changed everything. New ignition, FPR, plugs, fuel filter, ignitor, coil, cap, rotor, injectors. Didn't think of changing the wires becuase they were only about 6 months old. At least when I finally got it running right I had brand new everything and a bunch of spare parts. Accel </TD></TR></TABLE>
Old Apr 23, 2004 | 12:54 AM
HAHAHA, yeah. Sorry I didn't clarify.
Old Apr 23, 2004 | 05:14 AM
95GSRTT
Guest
Posts: n/a
My wires come off periodically, mainly just when I am running hard on the car. I had this problem for like 2 months before I found out I was only running on 2 cylinders b/c the 1st and 4th wire plugs came off. Would getting new wires fit tighter so they dont come off? Or should I be worried that my engine is popping them off by pressure/blow by?
Old Apr 23, 2004 | 10:18 AM
Default Re: idle problems and misfiring (95GSRTT)
If you have blow-by popping off your spark plug wires you have some serious problems. HAHAHA. Doesn't happen.
Old Apr 23, 2004 | 10:28 AM
jonsteR's Avatar
I had the same problem before even when i had just replaced my ignitor. Make sure you buy an OEM one. I replaced mine with one from pep boys and it gave me the same problems you were describing after a few months. I ended up getting another used distributor and it solved the problem.
Old Apr 24, 2004 | 02:57 PM
porschekremer's Avatar
Default Re: idle problems and misfiring (jonsteR)
coptzer what the hell you always know you get ahold of the cruisner if you have problems like this... j/k lol but def. wanted to bump for car looks hott love that color cant believe you wanna sell it...
def. a sweet ride
hope you find the problem w/ the idle, im sure you will...
Old Apr 29, 2004 | 09:09 PM
honda head's Avatar
Me and my friend just did a lash adjustment on his car. When we went to start it up it sputtered like it was misfiring. I'm assuming since the car is a 99 that maybe a stock wire just crapped out, but does anyone else have a suggestion? Thanks
Mike
Old Apr 29, 2004 | 11:08 PM
honda head's Avatar
Default Re: idle problems and misfiring (honda head)
Well, we messed with the plug wires. Seems to have smoothed out somewhat. There is still a misfire, a CEL came on. Don't know the code though. Plus the car is running filthy rich. It smells like someone poored 93 right underneath the exhaust. Any ideas?
Old Apr 30, 2004 | 02:48 AM
alfaaay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda head &raquo;</TD></TR><TR><TD CLASS="quote">Well, we messed with the plug wires. Seems to have smoothed out somewhat. There is still a misfire, a CEL came on. Don't know the code though. Plus the car is running filthy rich. It smells like someone poored 93 right underneath the exhaust. Any ideas?</TD></TR></TABLE>
Check the gap on the spark plugs. If you took them out, you might have messed up the gap if you didn't carefully put them back in (banging the side walls).
Old Apr 30, 2004 | 08:32 AM
honda head's Avatar
we hadn't messed with the actual plugs, but turns out the number 1 and 2 plugs were just extremely loose. Took about 4-6 turns to actually seat them in the head. Misfire isn't there any more, but the car still runs pig rich and idles in the 1000-1300 range. When we rev the engine to get the idle to drop they drop so low the car stumbles to stay running and then slowly jacks its way back up above 1K. There is an AFC in the car, but the fuel curves haven't been altered. V-Tec engagement has been lowered 400 RPM but I doubt that would effect the car running extremely rich. It through a CEL again but we haven't driven it anywhere to pull the codes yet. It's just weird that after it ran perfect, with the exception of some valve train ticking, that after we pull the valve cover and adjust lash that the car would run so rich. We're going to redo lash and see if that effects anything. We just need to find what's causing the mixture to become so rich.
la_teta
27
Sep 26, 2012 01:37 PM
cilvia
11
Apr 2, 2008 06:00 PM
emooheo
Aug 9, 2007 03:35 PM
dayaftertomorrow
Feb 3, 2005 06:31 AM
GreenEX
Jan 23, 2004 08:47 PM
