fuel pump set up for hondata
would it be o.k to use the MSD in line pump that the rev hard kit gave me with a Walbro intank pump to be used with a hondata or would I need a better in-line pump like a Bosch?
[Modified by Mikex25, 2:48 AM 10/31/2001]
The Bosch is good cus it can sustain high Fuel Pressures....unlike some others...
If your going Standalone (Hondata), then you dont need more ~50-60PSI of Rail Pressure ever...cus your using bigger injectors...So You don't NEED a Bosch, but they are still nice pumps.
Suprdave
Suprdave
SO all I need is Walbro fuel pump (what do they cost?) Hondata, and 440's or 550's? Do you still need a fmu or does the stand alone controle the amout of fuel for every psi of boost?
Go read the FAQs on http://www.hondata.com. It will answer this question as well as the ones you have about standalones.
Trajic
Oct 9, 2001 10:37 AM
