Machining my Block
Old Apr 21, 2004 | 01:12 PM
Anthrax-VX's Avatar
Default Machining my Block
ok.. my question is.. i am going to be boring out my b18a1 and i am boring it to 84 mm . i just want to know is it safe to do taht without block guarding and without sleeving. Will it be strong enough to hold for standard NA high compression like 12:1 .. if yes.. will it be strong enough to hold 8.5:1 with 12lbs of boost?
i also want to know if any of you know a place that does it cheap in san diego.
i got napa quote at 25 per cyl. lemme know if u have a better place
Old Apr 21, 2004 | 01:31 PM
Tmack's Avatar
Default Re: Machining my Block (Anthrax-VX)
I think the cylinders will hold the compression allright BUT I dont think they will handle the stress of being revved, nor will the head gasket survive without some sort of reinforcement (ie. o-rings, cylinder brace etc.) Better safe than sorry right??
Old Apr 21, 2004 | 02:18 PM
AzG35's Avatar
Default Re: Machining my Block (Tmack)
Sorry, you can't bore a stock B18a block to 84mm. You MUST resleeve to do so.
Old Apr 21, 2004 | 03:50 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Machining my Block (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, you can't bore a stock B18a block to 84mm. You MUST resleeve to do so.</TD></TR></TABLE>
Yes, you CANNOT do that to a stock block. Honda recommends AT MOST to bore 0.020 over, which is 81.5mm.
Anything more, and you will need to have it sleeved....preferably ductile iron sleeves through some reputable aftermarket company.
Old Apr 21, 2004 | 03:51 PM
Kendall's Avatar
Contact earl on this board for more information regarding sleeving. He'll get you a good deal as well.
Old Apr 21, 2004 | 09:40 PM
Anthrax-VX's Avatar
Default Re: (Kendall)
whats earls handle?
Old Apr 22, 2004 | 01:25 PM
Tmack's Avatar
Default Re: (Anthrax-VX)
ya i thought 84 mm was a little much, learn something new everyday I guess
RACEPAK
May 24, 2008 11:03 PM
JDM2ndGen
Mar 7, 2004 04:05 PM
vtecb20coupe
Jan 29, 2004 12:23 AM
aut0tek
Jan 8, 2004 04:19 AM
SilverSellout
Nov 23, 2003 10:50 PM
