VAFC RPM Monitor Question
Old Apr 21, 2004 | 08:11 AM
Luserkid's Avatar
Default VAFC RPM Monitor Question
Ok i searched and most of the threads that deal with RPMs for the VAFC are usually "why does my tach say this and my VAFC rpm say that"
This isnt one of those questions. My question is. On the Analog setting for the RPM mine only goes to 6rpm, while on the box and the paper on the box it shows it going up to 8 in 2's (2, 4, 6, 8) . I was wondering if anyone knows how to change that setting to 8 or maybe 10.
I looked through my manuel and it didnt help me much. And that paper that i saw it on was in Japanese and i dont speak a bit of it. Thanks if anyone knows.
Old Apr 21, 2004 | 08:24 AM
2lua's Avatar
Default Re: VAFC RPM Monitor Question (Luserkid)
what is your controller, field or apexi???
Old Apr 21, 2004 | 08:36 AM
Luserkid's Avatar
Default Re: VAFC RPM Monitor Question (2lua)
apexi
Old Apr 21, 2004 | 08:44 AM
Grimm's Avatar
I don't think you can, I think apexi has it set that way to give you the most accurate read out?
Old Apr 21, 2004 | 08:45 AM
2lua's Avatar
humm... now you got me thinking about it, i don't have one, but i installed quite a fews, and all i did is making sure everthing working then they take it to the dyno shop and get it tune... let me try to get a hold of some of them and see. i will let you know.
Old Apr 21, 2004 | 08:54 AM
Happyman's Avatar
I just use the digital RPM setting that shows numbers...i like it better anyways.
Old Apr 21, 2004 | 09:16 AM
redrum eg6's Avatar
you can set where the analog tach and the range on the graph go in the settings on the vafc. i dont remember off hand how to do it but i changed mine to be that way.
go into the settings and play around with it.
Old Apr 21, 2004 | 09:17 AM
havok hybrid's Avatar
Default Re: (redrum eg6)
factory tachs are WAY off... The vafc is correct.
Old Apr 21, 2004 | 10:04 AM
TeamCracka's Avatar
Default Re: (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">factory tachs are WAY off... The vafc is correct. </TD></TR></TABLE>
Are you sure? The tach and VAFC both hook up to the same wire from the ECU.
Old Apr 21, 2004 | 10:16 AM
Happyman's Avatar
Default Re: (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure? The tach and VAFC both hook up to the same wire from the ECU.</TD></TR></TABLE>
The difference is digital vs analog. of course digital will be "more correct"
Old Apr 21, 2004 | 10:22 AM
92b16vx's Avatar
My old factory was with in 50 rpms, my new one is within 200 at all times. Not to far of for a factory tach.
Old Apr 21, 2004 | 11:20 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">I just use the digital RPM setting that shows numbers...i like it better anyways.</TD></TR></TABLE>
Yea thats what i use too but i was flipping through the monitors and saw that the tach was only at 6 so i got to thinking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrum eg6 &raquo;</TD></TR><TR><TD CLASS="quote">
go into the settings and play around with it.</TD></TR></TABLE>
Thats what i dont want to do because i dont want to mess anything up .
Old Apr 21, 2004 | 11:50 AM
hondamagic98's Avatar
Default Re: (Luserkid)
i have my vafc at 8000 rpm, gotta go to your graph scale..and it should be under there, 6k rpms-10k rpms....
Old Apr 21, 2004 | 12:46 PM
TeamCracka's Avatar
Default Re: (hondamagic98)
Right, theres a setting for graph scale, so if you've got a VTEC B-series motor you'll want to set it at 8200. I've got mine in the ash tray so the analog doesnt really come in handy.
Old Apr 21, 2004 | 12:49 PM
TeamCracka's Avatar
Oh, I've always wondered why they have the option for more or less cylinders and other options that dont pertain to Honda motors, but they are made to control VTEC?
Old Apr 21, 2004 | 12:51 PM
Luserkid's Avatar
Default Re: VAFC RPM Monitor Question (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">Oh, I've always wondered why they have the option for more or less cylinders and other options that dont pertain to Honda motors, but they are made to control VTEC? </TD></TR></TABLE>
Accord V6? Or NSX?
Old Apr 21, 2004 | 12:55 PM
Luserkid's Avatar
And it was the Graph Setting. Thanks.
JayDeeEmm
Sep 3, 2008 01:50 PM
ILoveJDM.
Nov 16, 2006 05:12 PM
Civichatch2k
Sep 30, 2002 05:44 PM
4doorH22
Jan 4, 2002 09:50 AM
