Adding AC to a DX
Old Apr 21, 2004 | 07:24 AM
thug252's Avatar
Default Adding AC to a DX
I have a 92 honda civic DX and want to add power steering and AC to the car. I have all the components for a Civic w/ power steering and AC already and want to know how involved it is to do the conversion. I am not afraid to remove the dash as this is my project car and downtime is not an issue. I am prepared to install the evaporator, AC compressorm, Reciever drier and AC lines but do I also need the climate control from a EX or can I use mine. Also how involves is the wiring? I am not going to sell the car for one with AC, and have my mind set on it. Can some1 help me out. A search only yielded those of you removing AC not adding it. Also, MY DX has a SOHC VTEC. Will all the parts from the 1.5L SOHC engine fit my SOHC VTEC?
Old Apr 21, 2004 | 08:00 AM
PokeyD16Z's Avatar
Default Re: Adding AC to a DX (thug252)
Can't really help you out with much of the other things, but I can tell you this: You will need to remove the dash to get the evap in. Also, you do not need the climate control from an EX...there is a block-off plate over the right side of your climate control that you take off and put the AC button in its place.
Old Apr 21, 2004 | 08:04 AM
punku10's Avatar
can't help you with installation.. sorry but i do have the entire AC removal parts from my car D16Z6 if you need anything let me know...
VolRex
Aug 7, 2011 04:54 PM
whitehf
Aug 25, 2006 08:38 AM
lv6l
Jun 28, 2006 03:00 AM
infinkc
Feb 19, 2005 03:23 PM
