I got a?
Old Apr 21, 2004 | 06:30 AM
hondaracing1's Avatar
Default I got a?
I just swaped a d15b into my car yesterday or well not me but a shop did but like latly when ive been sitting idling in neutral a tiking sound comes from around the engine area then when i engage the clutch it goes away, it may be normal but idk and sometimes it wont do it unless after a long drive
Old Apr 21, 2004 | 06:53 AM
Ricey McRicerton's Avatar
Default Re: I got a? (hondaracing1)
Input shaft bearing is bad. If you depress the clutch and the sound goes away it's the input shaft bearing (otherwise known as the mainshaft bearing for Emerika). Search for the thread by BauleyCivic to see how to fix it.
And next time make your thread title something helpful for future reference.
Old Apr 21, 2004 | 07:08 AM
BauleyCivic's Avatar
Risky Business
Default Re: I got a? (Ricey McRicerton)
What he said ^
Input Shaft Bearing
Symptoms: https://honda-tech.com/zerothread?id=590820
Replacement: https://honda-tech.com/zerothread?id=596873
A pic:
What happens if you don't fix it soon:
The ISB will get chewed up and thrown all over the tranny...destroying it and locking it up. Tom (B18C5-EH2) said he drove around for a few months on a bad one and he was locked out of gears (destroyed tranny).
Old Apr 21, 2004 | 07:10 AM
Default Re: I got a? (BauleyCivic)
^^ Go ahead and order the bearing from Honda. I tried to order 3 of them from my local Advance Autoparts because they could get it to me overnight, and ended up not getting the right one through them. Just go ahead and get the Honda part.
Also, it's not a very hard job at all. Just pulling the tranny sucks.
Old Apr 21, 2004 | 10:40 PM
Emong3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1 &raquo;</TD></TR><TR><TD CLASS="quote">I just swaped a d15b into my car yesterday or well not me but a shop did but like latly when ive been sitting idling in neutral a tiking sound comes from around the engine area then when i engage the clutch it goes away, it may be normal but idk and sometimes it wont do it unless after a long drive</TD></TR></TABLE>
Damn my car makes <U>humming noise </U> but there is no ticking sound when idling and when I press the pedal, it goes away. I also hear the same humming noise when running on first gear and reverse. I have learned to live with it for more than a year now. tried replacing the tranny oil but humming noise is still there.
Could it be the same problem?
craigaria
23
Nov 24, 2012 02:18 PM
joelmatt89
Aug 11, 2010 06:35 PM
ether.real
Oct 7, 2009 06:49 PM
ksJoe
19
Dec 30, 2008 07:21 PM
BI8B
Sep 16, 2003 06:14 AM
