Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Removing rotor deposits?
Old Apr 21, 2004 | 06:00 AM
StageOne's Avatar
Default Removing rotor deposits?
Due to poor weather conditions, I had issues bedding in my pads properly. The week before the first HPDE, it was raining with temps about 35. Yes, the entire week was that bad. I tried to bed in the new pads, spec VRs, but with no grip (cold and wet), the ABS engaged almost everytime and I could not get enough heat in to the brakes. Hoping that was enough, I headed to the track.
By the first dry session, I had bad vibrations under braking. I tried to re-bed the pads in but to no avail. I'm still stick with vibrations when I have any heat in the rotors. I tried using a little bit of sandpaper on the rotors, but that did nothing.
Is there any way to remove the deposits on the rotors?? Or should I mark that down as "How not to bed in new pads" and get another set.
Old Apr 21, 2004 | 07:24 AM
Xian's Avatar
Default Re: Removing rotor deposits? (StageOne)
get some emory cloth from the local hardware store... lightly sand down the rotors... re-bed the pads.
That should get them fixed up for you.
Christian
Old Apr 21, 2004 | 07:26 AM
Todd Reid's Avatar
Default Re: Removing rotor deposits? (Xian)
or if the deposits are really bad, take the rotors to a shop and have them LIGHTLY turned. LIGHTLY. otherwise, the idiots will shave off about 0.030" of perfectly good metal. you just need them skimmed; no metal removed, just the cementite deposits.
good luck
Old Apr 21, 2004 | 07:30 AM
Crosser's Avatar
Stupid question, you have cleaned the rotors with brake cleaner correct?
NuRon
Mar 10, 2008 05:51 PM
onyx00
Sep 16, 2004 11:00 AM
valentinecr
Jun 18, 2004 10:48 PM
LudeyKrus
Jun 10, 2003 03:40 PM
mr tl
Sep 20, 2002 08:22 PM
