Will ITR final drive fit in LS tranny?
Old Apr 20, 2004 | 11:44 PM
Thrillhouse's Avatar
Default Will ITR final drive fit in LS tranny?
Will the ITR final drive fit into the LS hydro tranny. What exactly do I have to do if it is possible. I was told it should work and change the gear ratios, so they are closer together. BTW I have a 99 ls if that matters.
Old Apr 21, 2004 | 06:44 AM
Dan GSR's Avatar
Default Re: Will ITR final drive fit in LS tranny? (Thrillhouse)
in order to run a 4.4 final drive from a ITR/GSR
you will need ITR/GSR differential
ring gear bolts
and counter shaft
not worth the trouble in my opinion....just get a b16 trans or itr trans if u can afford it
Old Apr 21, 2004 | 05:42 PM
integramic's Avatar
I believe you also need the first gear , collar, and needle bearing(110.00 for all). Your talking about the 4.478 right?
Old Apr 21, 2004 | 09:13 PM
Default Re: (integramic)
yeah, so how much would it cost?
Old Apr 21, 2004 | 10:42 PM
Dan GSR's Avatar
Default Re: (Thrillhouse)
for the labor? parts? or both?
Old Apr 21, 2004 | 10:53 PM
MAD ITR 55's Avatar
Default Re: (Dan GSR)
You would be better of buying a b16 or Type R tranny.You can find B16's for $400-$800.Type R tranny's go for about $1,000-$1,600.
weavertime1
Transmission & Drivetrain
Jun 3, 2012 11:08 PM
Knucklehead7
Jan 28, 2008 10:01 AM
b18bEKcoupe
Jun 28, 2007 11:18 PM
Octoman
Oct 16, 2004 02:56 PM
Audi A4
Jul 9, 2002 07:27 PM
