d15z1... Boosting it maybe..
Old Apr 20, 2004 | 07:40 PM
fwdftw's Avatar
Default d15z1... Boosting it maybe..
hey yall im getting a d15z1 /w a z6 intake manifold in my 92 EG .. im gonna boost it but wondering what it will probably do in the numbers ?? is this a smart idea?? gimme some options on this swap
Old Apr 20, 2004 | 07:49 PM
fwdftw's Avatar
Default Re: d15z1... Boosting it maybe.. (Milano92Hatch)
also info on the differnce between this and a Z6/y8..
Old Apr 20, 2004 | 08:09 PM
meanTheDope's Avatar
is that the vx motor?
Old Apr 20, 2004 | 08:21 PM
Discosteak's Avatar
Default Re: d15z1... Boosting it maybe.. (meanTheDope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanTheDope &raquo;</TD></TR><TR><TD CLASS="quote">is that the vx motor?</TD></TR></TABLE>yes!
Old Apr 20, 2004 | 08:25 PM
Default Re: d15z1... Boosting it maybe.. (BADEG6)
to be honest...i dont think that will be a good idea...try getting the whole d16z6 or the y8 motor then boosting that...because the vx motor was made for gas efficiency...not for performance...but if you do decide to do it...lemme know how it turns out...peace
Old Apr 21, 2004 | 11:08 AM
fwdftw's Avatar
from what i hear thou.. /w a z6 intake mani it will put out just as much a y8.z6... and it has lower compression.. making it want boost more
Old Apr 22, 2004 | 09:47 AM
Default Re: (Milano92Hatch)
but it dosent have a real vtec...the vx has vtec e which was made for gas efficiency where you can put out more mpgs. But if you can find someone who did it i would like to know about it. Sounds like a good way to go budget wise. lemme know ... thanks
Old Apr 22, 2004 | 09:50 AM
ABK's Avatar
ABK
Default Re: (meanTheDope)
yeah vx motor is not going to put out nearly as much power, simply because it doesn't have vtec.
Old Apr 22, 2004 | 09:52 AM
Uncle Ben's Avatar
IMHO which kit you get will make some difference. I witnessed a z6 with a DIY turbo get beat by a y7 with a TRUE greddy kit...
Old Apr 22, 2004 | 11:43 AM
CivicVX94's Avatar
yeah i have a 94 vx and I'm swapping the engine out, I want to boost it but the internals can't handle it and it's 92 hp isn't quite cutting it. So I'm going to start with a higher hp engine. Also props to ya if you find a turbo for a d15 I've tried forever and nothing....but I'm trying to find a d16z6 to swap and boost. a d16z6 is basically the same as the y8 (both 1.6 SOHC vtec) except the y8 comes out of a 96-99 ex (i think it's ex but i could be wrong), so it's a little newer so a little more. but your like me and fall into the 92-95 category i would go with the z6 cause it's from the same year and model car so all after market parts (header, intake, exhaust, turbo, etc..) should still bolt on w/o mods. hope this helps, peace. o and i just bought a cat back exhaust system and the **** doesn't fit cause of the stock header on the d15z1, the down pipe is a part of the system not a separate piece that just bolts on. so i have to have it custom installed
Deadlock281
Dec 28, 2010 12:02 PM
Mikes2000civicsi
15
Jan 11, 2007 06:49 PM
sohctodohc
Jun 27, 2005 10:38 AM
trooper0641
Oct 22, 2004 09:42 PM
spyderracing
Jul 6, 2004 01:07 PM
