can you put a s-cover on an e-cover sc61?
Reason i ask is due to back order i seem to be only able to get the sc61 with the s-cover. Can i just swap covers later when i get an e-cover? Hope this questions not dumb. thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3LSLO »</TD></TR><TR><TD CLASS="quote">y would u want the smaller cover?</TD></TR></TABLE>
It actually works really good with the smaller cover.
Just wanna try keep the spool up time down a bit. And dident a guy do a review on here between the e and s cover. Said like the s cover only mad e a few more horses but the spoool was a bit longer. Maybe im making this up, cant remember.
Spool wont really be affected unless you change out the exahust wheel or turbine housing to a larger one. If there is any lag it will be unnoticable.
art
art
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">no the backing plate is different </TD></TR></TABLE>
if this is true than why do places offer it as a upgrade for like 100 dollars? or can you only get the S housing upgrade befiore you purchasethe turbo? its not something you can try to upgrade after you buy a e cover sc61 and want to upgrade to S later?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy »</TD></TR><TR><TD CLASS="quote">
if this is true than why do places offer it as a upgrade for like 100 dollars? or can you only get the S housing upgrade befiore you purchasethe turbo? its not something you can try to upgrade after you buy a e cover sc61 and want to upgrade to S later?</TD></TR></TABLE>
You can upgrade it at later time but you have to get a new backing plate as well as get the turbo balanced again because the wheel has to come off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">
It actually works really good with the smaller cover.</TD></TR></TABLE>
