my brake rotors cracked, why?
Old Oct 30, 2001 | 01:13 PM
ryan12321's Avatar
Default my brake rotors cracked, why?
my stock brake rotors on my si cracked. I got endless na-y pads but those were probably only on there for a few thousand miles. Is that what might have caused this to happen? the car only has 29k on it and i've never heard of stock rotors cracking before.
Old Oct 30, 2001 | 01:14 PM
White Dragon's Avatar
Default Re: my brake rotors cracked, why? (ryan12321)
Do you track the car at all? If so, how much?
Old Oct 30, 2001 | 01:16 PM
GRM Scott's Avatar
25 Year Member
How agressive are you on the brakes? Heat cycles are what fatigue brake rotors...going hot to cold, hot to cold is much harder on them then say keeping them really hot for 2 hours and cooling them down slowly. Where did the crack occur on the rotor? And how many miles were on the rotors before you switched to new pads (the new pads may have been hitting different areas of the rotor than the stock pads that the rotors were broken in on, just a thought.)
Old Oct 30, 2001 | 01:33 PM
ryan12321's Avatar
Default Re: my brake rotors cracked, why? (Aleph)
I'm pretty aggressive on the brakes. There are alot of small cracks going vertical on the rotor. I think I may have 5k miles on the pads and they look to be about half gone, not sure exactly how much is left but thats just from looking at them from outside my wheel.
I have about 10 auto-x events on the rotors, I'd say 3 of those with my endless pads. No actual track time though. 3 trips to deals gap and one to the blueridge parkway with heavy braking at both places.
I'm still not sure what caused it and need to find some new rotors quick.
Old Oct 30, 2001 | 01:35 PM
MiraiZ's Avatar
heat...get some heat resistent rotors...althogh i must say..stock ITR rotor are pretty good with heat..poor with rust though
Old Oct 30, 2001 | 01:40 PM
Warren's Avatar
Wrong-Way Wang
When you say crack, do you mean it cracked ALL the way through? Or are you just talking about surface cracks. Surface cracks are normal if you track the car. It's when it cracks all the way through that you are screwed.
Warren
Old Oct 30, 2001 | 01:43 PM
ryan12321's Avatar
Default Re: my brake rotors cracked, why? (Warren)
Its surface cracks but it shouldnt be happening should it if i dont track the car. i do drive hard but nowhere near what i would on a track. But you're saying i shouldnt worry that much if they are not cracked all the way thru?
Old Oct 30, 2001 | 01:44 PM
MiraiZ's Avatar
maybe they're cooling too quickly...ever spray water on tem while they were really hot?
Old Oct 30, 2001 | 02:17 PM
ryan12321's Avatar
Default Re: my brake rotors cracked, why? (MiraiZ)
nope, never sprayed water when they are hot, well maybe once or twice a real long time ago.
Old Oct 30, 2001 | 02:52 PM
Cosworth's Avatar
Ryan - are you parking the car outside at UGA? It's been awfully cold the last few weeks. Maybe you heated up the brakes too hot and it cools too quickly. If you do decide to buy new rotors, you can get Brembo OE replacement for cheap.
Old Oct 30, 2001 | 02:59 PM
Big Phat R's Avatar
Go with OEM Brembo replacements - much better than stock rotors. They come heat treated.
Cryo treated rotors are the best. There is also some sub-harmonic vibrational treatment thingamabob you can get done too - but $$$.
Old Oct 30, 2001 | 03:13 PM
ryan12321's Avatar
Default Re: my brake rotors cracked, why? (Big Phat R)
i do park outside but i dont really heat up the brakes around here that much. I will probably get the brembo oem replacements. How long can you typically drive if they are just surface cracks and not cracked all the way thru.
dragonkx
13
Jun 29, 2010 07:37 AM
a.wax
Sep 15, 2007 06:53 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
::MYCORD::
Jul 11, 2004 03:00 AM
accordhybrid
May 23, 2003 12:58 PM
