Tial WG question. easy answer i am sure
Old Apr 20, 2004 | 02:25 PM
Trak_Day's Avatar
New User
Default Tial WG question. easy answer i am sure
How difficult is it to get the top off to check the spring? I need to figure out which spring i was sent, because i already got the wrong color.
Old Apr 20, 2004 | 02:27 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Tial WG question. easy answer i am sure (DroppedGSR)
it's like 6 allen screws and it's off, nothing too too hard man good luck
Old Apr 20, 2004 | 02:32 PM
Trak_Day's Avatar
New User
Just wanted to make sure, i started that and felt like i was going to break it. so i stopped and thought i better ask and make sure!
Thanks
Old Apr 20, 2004 | 02:37 PM
Trak_Day's Avatar
New User
OK maybe not so easy. I am struggling trying to get these off. Very tight.
Anyone?
Old Apr 20, 2004 | 03:12 PM
Boofster's Avatar
Default Re: (DroppedGSR)
It's very easy. I did it the other day. I'd remove it from the car and then put in on a table first. You need to push down on the top and then undo the bolts with the allen wrench. The spring is actually pushing against the top so it will create pressure on the bolts. Wash it off nicely and lube up the rubber inside it with some silicone spray while it's open.
I bet if you don't know what spring it is, it's probably the green one (0.5 bar)
Old Apr 20, 2004 | 03:19 PM
Trak_Day's Avatar
New User
Heres the problem i have a blue spring. but i cant tell if its the large spring or not? how tall is the large spring? small spring? diameter? how do i tell which on it is. it better not be the large. I cant have 1bar being my lowest setting. I will never have traction
Old Apr 20, 2004 | 03:25 PM
VNTEC's Avatar
B A N N E D
I think the blue springs are .6 bar, = 8.7 PSI or so, basically 9.... They are color coded
Old Apr 20, 2004 | 03:28 PM
TurboBumblBee's Avatar
Default Re: (VNTEC)
where do you order new springs? and how do you tell which spring color and size is what?? thanks..i currently have a 8lbs spring im guessing cause my boost controllor is not hooked up and it gets to about 8psi on the boost guage..
Old Apr 22, 2004 | 10:20 AM
Default Re: (Boostfedb18c1)
ttt
Old Apr 22, 2004 | 10:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
I believe b18bturbo carries replacement TiAL wastegate springs.
DELshaneSOL
Feb 25, 2012 10:09 AM
TylerB
Jan 27, 2010 05:34 PM
Arturbo
Mar 13, 2007 04:55 PM
blackpearlcivic
Apr 10, 2006 04:11 PM
DigitalFusion
Jul 27, 2004 11:07 AM
