WTF is up with my plugs, am I running lean at idle? 56k die
Thanks for the links,
I think that my plugs are normal according to what I just read :D
Canuck who is happy now!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">Sunoco 94 octane</TD></TR></TABLE>
94 octane at the pump must be nice!!
How old are those plugs??
Arno-who is jealous cuase SoCal gets 91 at the pump
plugs are about 15k KM old. You can get 94 octane at Sunoco or 93 Octane at Pioneer gas stations in Toronto
look rusty to me, try getting some new ones and some new plugs and make sure the plug wires seal right over the valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clicky Pow »</TD></TR><TR><TD CLASS="quote">Just a little curious, What are you mods?</TD></TR></TABLE>
Jun type 3 Cams
Jun dual valve springs.
Jun titanium retainers
Jun cam gears
Jun ported and polished head
Skunk 2 intake manifold (port matched to head)
66 MM bored B16 throttle body
AEM Cold air intake for Integra type R (3" diameter)
Civic type R pistons (12.1:1) compression ratio
RC Engineering 440 cc/min injectors
B&M fuel pressure regulator and fuel pressure gauge
DC Sports JDM 4-1 stainless steel header with 2 1/2" collector
Carsound High flow cat 2 1/2" - resonated test pipe for track use
Kakimoto R catback exhaust (70 mm piping)
Clutchmasters stage 3 clutch with carbon-kevlar friction disk
Clutchmasters 7.5 lb aluminum flywheel
Energy Suspension motor mount inserts
Spoon Sports thermostat
Spoon Sports thermo-switch
Spoon Sports 1.35 bar radiator cap
Spoon Sports magnetic oil and transmission drain plugs
Integra type R transmission with 5.029 Cusco final drive
Hondata programmable ECU (9500 RPM redline) with custom fuel/timing maps
Autometer phantom electronic fuel pressure gauge (full sweep)
Autometer phantom electronic exhaust gas temperature (full sweep)+ pyromoeter
Autometer dual gauge bezel
EDM Integra type R gauge cluster
MSD digital 6 plus ignition, (removed)
MSD blaster 2 coil, Pro distributor cap, (removed)
MSD 8.5 mm Superconductor sparkplug wires
For the full list http://www.big-blue-dragon.com
Jun type 3 Cams
Jun cam gears
for not putting type r stickers on
