CAR WONT START
Old Apr 20, 2004 | 12:10 AM
mm's Avatar
mm
Default CAR WONT START
Hi Guys!!!
I have a 93 honda civic (not sure though what is the engine), and the problem is that everytime i turn it off, Ive got a problem turning it on again.
It will start on my first attempt, but will eventually die. I need to wait for at least 5 min to get it running again.
Sometimes it will die by itself in the middle of the road, and as I have said, I need to wait for another 5 min again.
Ive tried checking for the ECU (just learned from this site how to do it, thanks), but my CEL isnt giving me any code. It lights permanently on.
Hope you guys can help me...
Im a newbie when it comes to cars (i just bought mine about 6 months ago), so please be detailed as possible...
Many Thanks!!!!
Old Apr 20, 2004 | 12:27 AM
19civic93's Avatar
Default Re: CAR WONT START (mm)
if your getting spark but not getting fuel and your fuel pump works then it's most likely the main relay. its an intermittent problem where the joints are not giving a good connection. its right next to your hood latch. remove the relay cover and desolder the joints and then resolder them and it should work fine or you can just replace it. i think its like 55 bucks at honda.
Old Apr 20, 2004 | 12:32 AM
19civic93's Avatar
Default Re: CAR WONT START (19civic93)
this is what the relay looks like.
Old Apr 20, 2004 | 05:51 PM
mm's Avatar
mm
thanks...I will look for it later....
But how will I know if Im getting any spark, or Im not getting any fuel, or if my fuel pump works fine?
as ive said, im a newbie so i really dont know these things....
Thanks again...
Old Apr 20, 2004 | 05:55 PM
mm's Avatar
mm
and by the way, how about the ECU and CEL not giving any codes(the CEL is always on), does it mean that my ECU is damaged?
Thanks..
Old Apr 20, 2004 | 05:57 PM
2+2Door's Avatar
if ur car is an automatic, it could be worn tranny.......thats all i know....
Old Apr 20, 2004 | 06:02 PM
mm's Avatar
mm
Default Re: CAR WONT START (GrRrr)
its manual....
do you have more ideas guys? so that i can check all of them in one shot this weekend....
Old Apr 20, 2004 | 06:58 PM
2lua's Avatar
try the dtc plug again sounded like you got it jumped properly. if the cel stay on with the motor running then you should 1 or more trouble codes.
Old Apr 20, 2004 | 07:24 PM
PUSHER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19civic93 &raquo;</TD></TR><TR><TD CLASS="quote">this is what the relay looks like.
^^^ just get that, it will fix your problem.... I have the same car and had the same problems. Go to your nearest honda dealer and order that, its either 40ish or 70ish I cant remember. But that will fix your problem. Its located on the drivers side, under the dash towards the left FYI.
Old Apr 20, 2004 | 07:55 PM
mm's Avatar
mm
Default Re: CAR WONT START (2lua)
yap, the cel remains on when i turn on the engine (with the jumper on)...
Old Apr 22, 2004 | 05:41 PM
mm's Avatar
mm
hi guys!
how will if i know if im getting any spark, and im not getting any fuel, and my fuel pump is working?
Thanks.
Old Apr 22, 2004 | 06:52 PM
cinq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mm &raquo;</TD></TR><TR><TD CLASS="quote">hi guys!
Thanks.</TD></TR></TABLE>
Listen to the guy up top..fix the main relay.....if you don't hear the whinning noise from the back seat when you turn the key to ign II...thats how u know your pump isnt working.....just fix the main relay...that will solve your problem.
Old Apr 22, 2004 | 09:01 PM
mm's Avatar
mm
Default Re: CAR WONT START (cinq)
thanks a lot guys!!!!
Ill give you an update once i have changed the relay....
Ill probably open another topic because my car has another problem, but Ill work on this one first....
Thanks again!
Old Apr 22, 2004 | 09:19 PM
dohcMONSTER's Avatar
good luck
Old Apr 23, 2004 | 03:54 PM
mm's Avatar
mm
Default Re: CAR WONT START (sohcMONSTER)
can you help me locate where is the main relay?
I tried looking for it for hours now, but I can not find it.
If you have some picture of the postion of the switch, relative to the car, please post it here.
Thanks.
albert7
29
Feb 7, 2017 03:12 PM
honda4fun
Sep 22, 2009 06:14 PM
onthagozc
32
Aug 24, 2009 07:54 PM
jdmjin
10
Jun 1, 2009 07:01 PM
MJPana
Jul 30, 2006 09:27 AM
