Car Wont Start
Car Wont Start
For some reason, i've been having some serious car troubles lately: main one being my car wont start when its relatively hot out (Outside temp >90º). if i move it to the shade for like an hour then it fires right up. im thinking some sort of vapor lock, but it doesnt seem right because i try to keep my tank above half full, and i doubt that all that could turn to a vapor or even come close to causing the problem. anyone got any ideas? no check engine light, no other fuel related problems that im aware of either.
Re: Car Wont Start (Slopoke)
could it realy be the mail relay even if it starts when its not incredibly hot out? ill check it out anyways.
EDIT: to be honest i dont think ive ever heard the fuel pump prime itself, maybe my hearing is shot >_<
Re: Car Wont Start (MJPana)
Try and listen for it. Its easier if you have someone else turn the key on and you get in the back and listen for it.
When the relay starts to go bad, it will work intermitenly. It is affected by heat too.
lol sorry, forgot to mention its a del sol, so there isnt much of a back to it. i did go out and check, didnt hear any priming
care to point me in the direction of the main relay. first honda ive owned so im unfamiliar with the locations of everything still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">
Its held to the body by a 10mm bolt.</TD></TR></TABLE>
like most other things on our cars
yeah. if you need a relay i got one for sale make me an offer.
im in canada and take paypal. i bought one thinking my relay was bad as i could bypass the relay fine. turned out i had a blown fuse (the ags or whatever one is with the srs relay. didnt think to check it as it was elevated)
either way, its gonna be your relay
if you want to test it, unplug the relay, take a wire and put it in slot #1 and #3, then another from slot #3 to #7
this jumps your ecu and fuel pump. alternatively u can use pin #5 as thats 12V from the ignition
SpoolinEK9
03-15-2005 04:25 PM
LilMissCrystal81
11-19-2004 11:26 AM
